Please allow me to brag a bit more.
Discussion in 'Gen 4 Prius Audio and Electronics' started by Chris Wolfgram, Dec 12, 2019.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    412
    167
    Sacramento CA
    2019 Prius
    So I had said in that other post below "Sound system finished"
    But I've been dialing in my DSP, and playing with my amp settings and geez, it's just hard for me to believe all this sound is coming from a Prius !
    It's going to be fun to be sitting in the waiting lot (for rideshare) surrounded by Prius's (or is that, Prii ?) and the rest of them wondering, Wth did he put in that thing ? Nothing Bro's.... Look, it's all stock. It's the new special, Prius concert series sound system :) lol
    Hey and one thing I wanted to add which I have been been happily surprised by; So it's Winter here in Nor Cal. Crappy, wet, and cold. So my HVAC system has definitely been running constantly, every time I'm stopped. And what I've found, is that even cranking my system up to moderately high levels, doesn't seem to have near as much effect on my battery, as does the fan at higher levels ?! In other words, with the fan cranked to 3/4's to full and the stereo very low or off, my car fires up to charge the battery like every 5 or 8 minutes....
    But with my fan very low or off, and beating on my stereo, it seems to go like 20 minutes before cycling on ? Hmmm. Okay. That's pretty comforting to know
  2. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    The engine needs to run more frequently to replace the heat extracted from the coolant by a faster-running blower, not the electricity required by the difference in fan motor speed.
    Tideland Prius and dig4dirt like this.
  3. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Okay. Learn something every day :) But the important thing here, is that the HVAC system was designed this way, and apparently its totally acceptable to pull that kind of amperage.... Yet my stereo (amplifier) apparently pulls a lot less than that :) Makes me a lot more comfortable :) Also, BTW, playing it as loud as I have yet, with max bass output, I haven't seen the tiniest flicker, or dimming of lights. Granted, I was already told here on this forum, that I would not see dimming or flickering, as the power converter is a lot more solid than a conventional alternator :) Which is very cool !
  4. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
  5. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Lol :) I used to have one of those !
  6. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
  7. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Hey but in all seriousness.... and I know nobody's asking, but....
    Having so much control over the end sound coming out of the speakers, with the 31 band IQ, is kind of a two edged sword. It means it can be dialed in to nearly perfect sound ('perfect' to my own tastes of course) but geez is this tricky ! Been playing with it for a week, and slowly but surely forming it into a smooth, gentle curve. I think I'm on about my 15th saved preset :)
    Now I'm trying to confirm my exact port tuning of the sub, so that I can use the variable subsonic filter to cut everything off from that frequency down, as everything below the port tuning frequency is out of phase, and just adds distortion + robs power.
    Most of this is "possible" without a very expensive Real Time Analyzer.... Just a lot tougher.
    I'm telling you though, I think there are exceedingly few Prius LE's out there that sound like this :) So happy with this setup :)
  8. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    In all seriousness, unless you are listening to your great system only while you are parked, don't the tire, road, wind, traffic, Prius ICE, etc. noises while driving obviate anything that can be accomplished with great audio hardware?
  9. Tideland Prius
    16,155
    That probably explains why several Gen 3 members added Dynamat with their audio upgrade. Not sure if Gen 4 owners are doing the same.
  10. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Actually, doing ride share, I spend plenty of time sitting in the car, listening to my stereo, while not moving.
    But since you should mention it, I'll admit that the quieter a car is, the lower and cleaner the stereo system can be played.
    But I will guarantee you, that even in a car which we agree is not the quietest car out there, I can easily play it clean, and still loud enough that you will hear every sound there is to hear (with a good recording of course) and road / interior noise won't have a chance.
    BTW, the system in my truck pulls so much juice, that even when I'm parked, I need to leave that big V8 running.... But it's so loud, sometimes I get worried... Like, "Wait... The truck is running right" ?
    In the truck, I can cover up nearly all road noise, on the freeway, with the windows down. The Prius is not quite like that, but probably sounds even better / more balanced
    #10 Chris Wolfgram, Dec 14, 2019
