Please check your Instrument Panel Dimmer control
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PhilBlank, Aug 9, 2015.
  1. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    2014 PIP Advanced with Tech Package.
    I was playing with the Instrument Panel Light control (Page 262 of the owner's manual) and I noticed that it goes from full-dark to full-bright and back the other way. It might as well be a toggle switch...;). It reminds me of an old rheostat that is badly wound (for those of you old enough to remember those sorts of things...;)).
    Anyway, wanted to know if any other PIP owners are experiencing this kind of issue? I am planning on having it replaced as the car is still under warranty.
    Thanks,
    Phil
  2. angelahortega
    angelahortega Junior Member
    29
    Ukiah
    This is a feature isn't it? It gives you the option to use it this way.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I believe Phil is trying to say that instead of dimming it is either at full intensity or off.
  4. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    My dimmer works as it should, a gradual progression either way.
  5. bisco
    52,863
    i will check mine. from memory, it works, but i keep it at full bright. it is a rheostat, isn't it? or have they developed an electronic control with old fashioned wheel?
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Ours works as a dimmer, with full bright after turning past the click at the top.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    IIRC, daytime and nighttime functions are different. Nighttime varies, but daytime is light or dark.
  8. PhilBlank
    86
    2014 Prius Plug-in
    I have tried it with the lights on and the lights off. Jim N is correct...as I move the wheel, it goes from very dark to very bright...and there is no gradual increase or decrease in lighting adjustment...
    Thanks...definitely sounds like a dealer to replace item at the next service...
    Phil
    P.S. I will try it when it is dark outside just to be sure that it doesn't make a difference.
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    No need to wait for nightfall. You can cover the ambient light sensor on the dashboard with a dark towel.
  10. TrinaF.
    TrinaF. Junior Member
    74
    24
    Southern California
    I don't use the auto light option. I use the day lights, and then on. The dimmer works the way you say, either full or light, this way. I have to manually switch it. If you have your lights on the auto setting, I believe it does the auto dimming as well.
  11. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I like my backlighting as dim as is readable so that I can preserve my night vision. Several times I have dimmed them to the point that the HSI screen isn't showing anything, and the first time I thought something had fried.
    Khawailad likes this.
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I would guess a potentiometer versus a rheostat. Much less electrically noisy, and brightness is probably a function of an ECU somewhere using the reference resistance provided by that thumbwheel.
  13. el Crucero
    1,628
    699
    Inland Empire
    Okay, to satisfy my own curiosity, I conducted a test last night and this morning. I left the light stalk in "auto" position in both cases. At night, the thumbwheel acts as a variable dimmer. During the day, the thumbwheel is either fully dimmed or fully bright, no variable dimmer. That's the way it works on my Prius.
