WTB Please delete.
Discussion in 'Private Sales' started by texasboy77904, Jan 30, 2016.
  1. texasboy77904
    texasboy77904 Junior Member
    92
    Please Delete.
    #1 texasboy77904, Jan 30, 2016
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    What happened, you didn't put the lowbeam bulb in straight? Always check bulb alignment after installing a new bulb by turning it on. A misaligned bulb will put out a very weak beam pattern.
    If the housing isn't melted, you can try removing the headlight housing from the vehicle, remove all bulbs and harnesses. Set it on a towel, then bake in the oven at a low temperature for a while. That may be enough to remove the moisture.
  3. texasboy77904
    92
    Please delete.
    #3 texasboy77904, Jan 31, 2016
