Please explain MPGe
Discussion in 'Prime Fuel Economy & EV Range' started by Pizza Driver, Oct 20, 2016.
  1. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Sure, but ultimately, you care about efficiency for three reasons:
    Cost per mile, which MPGe doesn't cover
    Resource usage, which MPGe doesn't cover
    Global warming potential, which MPGe doesn't cover
  2. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    Sure, however all of that data is listed on the car stickers where the MPGe is also shown.
    BTW, MPG doesn't give you that information either. It is just that we are so used to doing the conversions in our head, it doesn't matter.
    HypersonicPrime likes this.
  3. Oniki
    Oniki Active Member
    652
    500
    Colorado
    It does if you are starting from the same fuel source. Then the MPG (e or otherwise) is proportional.
    For example:
    If car 'a' is x mpg
    and car 'b' is 2x mpg
    Then car 'b' costs half as much to fuel, uses half the resources, and pollutes half the amount.
    Which is why I keep saying that MPGe is only useful in cars with the same fuel source.
    Don't mix MPG(e) electric with MPG(e) fossil fuel. Nonsense is sure to follow.
    bhtooefr likes this.
  4. HypersonicPrime
    75
    59
    NC, USA
    @Oniki, your statements have several errors again. For the benefit of other readers, I would refrain from making statements if you are ignorant on the subject. Here's one example to refute your latest claim that you can use MPG to compare pollution: car 'a' and car 'b' use the same amount of fuel on a 100 mile trip. The cars are identical in every way except that car 'a' does not have a catalytic converter and car 'b' does. In this case, car 'a' sends more pollutants into the atmosphere than car 'b' even though they have the same MPG. Another reason why MPG is not reliable for total pollution is that it does not reflect the pollution that went into manufacturing the vehicle, which is something you really can't ignore. Comparing pollution is complex and using MPG to compare pollution is unreliable. I already explained why MPGe is useful in comparing energy efficiency and costs between vehicles of any fuel source so I will not repeat that.
  5. Oniki
    Oniki Active Member
    652
    500
    Colorado
    I have only lived in areas where all cars have cat converters. I was not thinking of NC.
    You are right though, I should have expliicitly limited the emissions to CO2
