Please give me suggestions and help
Discussion in 'Generation 1 Prius Discussion' started by Laura Skovlin, Feb 18, 2015.
  1. Laura Skovlin
    Laura Skovlin Junior Member
    17
    northeast Oregon
    2002 Prius
    I
    warning lights came on again and this time I was able to see it was the "car with exclamation" lit up on the screen, then also the "triangle with exclamation" in the dashboard..... lasted a short while and then went away.... sigh. Sure doesn't seem like the traction battery should be going out at only 50K, and the 12 V was replaced at 32K.
  2. ChapmanF
    19,041
    Ok ... the exclamation-car is the most generic one, just means any of the trouble conditions the HV ECU is able to detect, while not specifically the battery (since the center, "main battery" icon isn't red) and not power steering (if the left, "PS" icon isn't red). So now it's just a matter of waiting for a Prius-capable scanner to read out whatever codes the HV ECU really is complaining about. There are literally dozens of possibilities, so it wouldn't make much sense to start taking stuff apart before having some codes to suggest where to start.
    -Chap
    Laura Skovlin likes this.
  3. bwilson4web
    16,547
    Any progress on getting a Prius-aware scanner?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Hi Laura, sorry you're having all those problems but my question is? How's the car driving? What kind of gas mileage are you getting? I'm convinced you don't have a problem (especially if the answers to my questions are: Fine and 41+mpg). At this point, I wouldn't buy a code reader, I wouldn't do anything. You're care has been driven very little in its life. Its bound to have some gremlins running around in there. In my opinion, the best thing you can do for your car is drive it and do regular maintenance. I really think you need to give this some time to "clear" out before you go rushing into traction battery repair.
    PS: I'm certain I will take a lot of heat for saying what I said so, I'm standing by for the barrage. :)
  5. ChapmanF
    19,041
    Here comes the heat. :)
    Given that we now know the car's warning display is not highlighting the battery icon, I completely agree with usnavystgc here about not rushing into anything involving the battery at all.
    I can't get behind the logic that "problem is not in battery ==> no need to read codes or fix problem." There is a whole car attached to that battery, with plenty of other things to go wrong, and somewhere we know something has. The exclamation-car icon is not lighting up just because of the moon. The problem might be very small and easy to fix, or it might be more daunting, but not finding out will not solve it, or even help you make important decisions like how much you want to invest.
    Especially if you are in a remote area without reliable Prius mechanics around, a code scanner of your own is likely to be the best $40 accessory you will have bought for your car, because whenever a light comes on in your car you will not be dependent on someone else to tell you what sort of problem it represents or how serious it might be.
    -Chap
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    I hear you Chap and there's absolutely nothing wrong with buying the code scanner.
    Here's why I say what I said:
    The car is only giving intermittent errors that don't even seem to affect drivability. With a car that sat around as much as that one did, that's totally expected. I'm betting if she simply drives it regularly, these indications will go away and not come back. I'm not saying don't fix the problem. I don't think there is a problem. My point is, lets give it some time to be consistent or go away. These cars like to be driven and when you don't drive them regularly, gremlins seem to appear.
    As I look at the totality of the situation, (she just got the car from someone who rarely drove it, the lights appear intermittently and inconsistently, there are no drivability issues, she is new to the Prius, the Gen I is finicky and can give you various codes that go away and never come back) my first conclusion would be, it just needs to be driven.
    If you look at the other side of the coin. You buy the code reader, you get a code but, you currently have no lights/codes. What do you do? Replace something? If you do replace that, how do you know you "that" fixed the problem? At the most she could get a code reader, read the code and file that in memory for future use.
    That's how I see it.
  7. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    The car is driving just fine, and yes 41+mpg. Occasionally, when the warning lights are lit, there is reduced acceleration, so I pull over and re-start and that takes care of that. Lights may stay lit, but eventually always have gone out.
    Don't know if this has anything do to with it -- but the cars prior owner lived in a mild climate (San Fran) and I live in a very cold climate, with temps below zero in the winter. First time we got the warning lights was the first time we started it after several days of below zero. We thought the extreme cold may have had something to do with it.
    In reading back over all the posts, I can't seem to find info about WHERE to buy the Prius code reader. I will probably, at some point, want to buy one, even though I'm inclined to have a "wait and see" approach, about the warning lights. Given the low mileage, for the age of the car, it doesn't seem like things should be going wrong, especially the traction battery!
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    I would venture to say that sitting in a cold climate for days would/could def be what caused your lights. In cold weather, your very small 12V battery will lose capacity. Additionally, when the car sits for days, it loses some of the capacity it has from internal loss/drain and keeping the memory of your computers settings. The fact that the lights clear out and the car drives fine further reinforces my theory. If it were me, I'd drive it as much as possible over the next few weeks and see what happens.
  9. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    where does one buy this scanner? :)
    also mentioned (above in other comments) were the need for a VOM (? don't know what that is) some cables to hook up (to what?) a laptop and software. also a VCI (is this the code scanner?) As you can tell, I have no experience at all, in this, but am willing to learn.
  10. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    A VCI with Techstream software is available on Ebay at around $25. To use this device you will also need a laptop preferably an old one running 32 bit Windows XP, Vista, or 7. The software can be made to run on 64 bit Windows 7 or 8, but takes more setting up. This system is as close as you can get to the dealer equipment, and replaces a hand held scanner. This is a must if you wish to fault find a Prius.
    A VOM is a volt meter or you can use a multimeter.
    John (Britprius)
  11. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    May I ask if you have done the simple things? Check your oil level, inverter fluid level, coolent level? With the car running, and in Park, remove the cap from the inverter coolant tank and check for turbulance. If there is no movement, you have a failed inverter pump. If everything checks out, turn the vehicle off, and check the battery connection in the trunk. Make sure the terminals are tight and securely fastened. If the Gen1 is the same as the Gen2, follow the ground wire to the body and make sure it is tight and there is no sign of degradation.
    Another, often overlooked, place to investigate is the HV Battery Fan. It is located, on the GenII in about the same area as the 12 Volt. A buildup of dust and animal hair, or a blocked vent by the rear passenger seat, can cause the HV Fan to inadequately cool the HV Battery. It is a good idea to remove this fan, every few years, and clean it. If that is the problem, I am sure the frequency of the issue will increase, as the outside temperature increases... Also, Please let us know what you find.
  12. bwilson4web
    16,547
    I had bought mine several years ago but for now:
    I have Windows XP running on a virtual machine on a Macintosh. I have not tested the others but know Windows XP works.
    As for a VOM, I'm partial to Harbor Freight:
    I would have suggested Radio Shack but they are going out business (are there sales yet???) Sears also has them as does WalMart.
    #32 bwilson4web, Feb 23, 2015
  13. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    thanks very much, I just ordered the VCI diagnostic cable
    #33 Laura Skovlin, Feb 23, 2015
  14. bwilson4web
    16,547
    I would like to reassure you that no one will abandon you after getting a miniVCI and VOM/multimeter. We will work with you to make sure these new tools, these new devices work and give you good data. We'll also go over the theory and background as much as you want. None of us were born 'knowing this stuff' and they sure didn't teach the miniVCI in 1964-68 when I was in high school.
    We want you to be the master of your car and learn how to find out what is really going on. Those error lights are OK but ambiguous. Too often the owner's manual just says either:
    • take it to a dealer, $$
    • tow it to a dealer, $$$
    What we're dealing with is not that hard and we'll help you go forward. But one thing would help, could you introduce yourself? For example:
    I'm a 65 year old, married engineer living in Huntsville Alabama working on a NASA contract for computer network engineering who studied mechanical engineering because I like it! The oldest of five boys, my farm-raised, professional parents expected me to be the baby-sitter . . . a common practice in farm families. My late Dad was a physician and at one time, pathologist and chief medical officer of the State of Kansas who retired after 45 years with the National Guard and Reserves. My Mom is living in Southeast Kansas and has two degrees, accounting and nursing. For fun, she raises miniature horses and runs a 100 acre farm.​
    The folks on this forum share our interest in helping Prius owners keep their cars on the road for a reasonable price with good reliability. So teaching folks how to do normal things like measuring what is going on becomes second nature. We're patient and persistent and hoping you'll find what we're doing interesting. If not, let's at least get your car running good enough again. <GRINS>
    Laura Skovlin and Britprius like this.
  15. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    since you asked..... :)
    "I live in rural northeast Oregon, married for 25 yrs., 2 children (born at home), one still in high school. I live on a farm, where we strive to grow all our own food, including meat. Gardening is my passion, as well as creating beauty around me. I love animals. And dancing. I am a dance teacher and caller of monthly square dances. I play banjo in a bluegrass band. Have been a licensed massage therapist for 30 years. Life is never boring."
    I have not done those things but thank you for suggesting!
    #35 Laura Skovlin, Feb 23, 2015
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Eclipse1701d did hit on a good point. If you could locate the inverter coolant reservoir, unscrew the cap, turn the car on and check for turbulence or flow, that would help us rule out one possibility. This requires only a flashlight or a well lit area.
    Report the results of that here.
  17. bwilson4web
    16,547
    Excellent!
    Before arthritis, my wife and were at C1 level and loving it. I also pick at the banjo but I don't try it when real people are around. <GRINS> We also keep two dogs for my wife. Now a beagle and a chiwauwau (from hell.) Still, they keep my wife happy and that makes my life better too.
    Do you have reasonable bandwidth to see Utube videos? We're more than willing to post references too good instructional videos on how things look. Alternatively, we'll be happy to post images showing how to use the tools.
  18. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    That is awesome you play banjo, Bob! Youtube videos have gotten me a long ways in playing (since no teachers anywhere near)
    Yes, I do use YouTube for a lot of things, it is a life line for sure. Husband just checked the inverter coolant and saw movement, so that isn't the problem. Oil level fine. Now to check the HV battery fan.... wondering if it is located in same area as the Gen2 is.... as mentioned above
    usnavystgc likes this.
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Now that Laura is getting a code scanner, this thread is headed in the right direction.
    While we wait for the poste, a question for the Prius experts:
    I know why you all have a VCI and tech stream;
    I wonder though about that being the first consumer choice recommendation of a code scanner for people like Laura.
    Much simpler, and dare I say easier to use, is a BlueTooth dongle attached to the OBDII port and a smartphone app like Torque for Android
  20. Laura Skovlin
    17
    northeast Oregon
    2002 Prius
    I
    checked this and there was indeed, flow!
