Please help. 07 Prius died an hour ago on the road and won't start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DomL 07, Feb 7, 2018.
Tags:
  1. Prodigyplace
    12,567
    11,781
    Central Virginia
    I thought Toyota specified full synthetic oil for the Prius. I remember my son using that when he had his Gen 2.
  2. Mendel Leisk
    41,483
    There's no mention of synthetic oil in the 2nd gen US Owner's Manual, just the spec'd weight of 5W-30.
    Prodigyplace likes this.
  3. JC91006
    16,769
    8,567
    I change my oil every 5000 miles on my gen2 cars using a synthetic blend for $2 quart. Seems to be working fine without issues
    Raytheeagle and Prodigyplace like this.
  4. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I’m a 2005 owner with 440,000 miles and thought I’d had everything happen. The good thing is a code reader is going to tell you what happened. You know (because of flashers and headlights) your 12 volt battery is good. You also know that the car was just fine before the bridge! So it is electrical there are 50 fuses including the Main hybrid Fuses in the rear. Hear is a list of them. You can check them all. You will soon know why it happened Toyota Prius Second Generation (XW20; 2004 – 2007) – fuse box diagram | Auto Genius
    iPhone ?
  5. Prodigyplace
    12,567
    11,781
    Central Virginia
    Fixed in post 16. A fuse blew due to a recalled part.
    Raytheeagle and SFO like this.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    DIY is always the answer.
  7. Berch1943
    Berch1943 Member
    146
    Arizona
    Any update on the situation?
  8. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Or, even the AM2 fuse
