Please help - dead 12v battery?
Discussion in 'Gen 2 Prius Main Forum' started by MotorisedRollinghams, Feb 2, 2018.
  1. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Which would be the peddle closest to the center console ;)
  2. Mendel Leisk
    41,483
    Removing the battery from the car and charging it with a 3~4 amp range smart charger, in your flat, would be the best approach to revive the battery. Still, in you scenario, having just bought the car, I think they owe you some help. The car likely sat unattended on their lot for donkey years.
    RCO likes this.
  3. Prodigyplace
    12,567
    11,781
    Central Virginia
    I understand.
    Thank you for being patient with us as we brainstorm for ideas.
    RCO likes this.
  4. Prodigyplace
    12,567
    11,781
    Central Virginia
    I did not know where the pedal is on the RHD car. That is why I did not say.
  5. MotorisedRollinghams
    MotorisedRollinghams Junior Member
    17
    16
    London, UK
    Ok, I tried jumping it with the jump kit this morning.
    Attempt 1: Horn came on, scaring the shit out of us. Car would not start
    Attempt 2: (5-7 minutes later, with the key inserted this time) Got the door alarm when I opened the driver's side door to press the on button - a good sign. Then when I pressed the on button it went green for a second or two and then again everything was off.
    Attempt 3: (Again, 5-7 minutes later) Nothing happened - no door alarm, no green light.
    I suppose what I'll have to do now is call the dealer and formally reject the car. Any thoughts?
  6. MotorisedRollinghams
    17
    16
    London, UK
    One idea - maybe I'm not leaving it long enough after pressing the button on the jump kit and trying to start the car? I'm allowing about a minute. Perhaps I should allow longer? Jump kit needs a recharge now so can't try right away.
    RCO likes this.
  7. Mendel Leisk
    41,483
    Starting should be possible as soon as jump starter is connected, no waiting period.
    RCO and Prodigyplace like this.
  8. MotorisedRollinghams
    17
    16
    London, UK
    I got it working! Turns out that we were using the jump kit incorrectly - we needed to start immeadiately as you say.
    I went to the petrol station (10 min trip) and filled up and it started again afterward. Then we decided to go on the daytrip (50 min trip) and left it for a few hours and again it started properly. My suspicion that this was a PEBKAC has increased somewhat. Will know more when I can get probes for the multimeter tomorrow.
    #28 MotorisedRollinghams, Feb 4, 2018
  9. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    There maybe an aspect of user error here in the use of the starter pack, but there is no doubt you have a 12 V battery that has seen better days. Your best bet is to get the agreement of the seller to part fund a replacement as you will need a new one sooner rather than later. It is best to get this sorted now, rather than let it become an ongoing nuisance that sours your Prius experience. I would recommend using a dealer to supply and fit a new 12 V battery as getting the right 3rd party battery in the UK is a mission. Are dealers still doing a fixed price of a new 12 V supplied and fitted for £110?
    Prodigyplace and RCO like this.
