PLEASE HELP! Home Charging Options for Prius Prime
Discussion in 'Prime Plug-in Charging' started by Edward.Howard, Nov 18, 2016.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,032
    Westminster, Colorado
    120V, 12A = 5.5 hours
    240V, 12A = 2.5 hours
    240V, 16A = 2 hours
    priuscatprimeguy and john1701a like this.
  2. John11heather
    John11heather New Member
    Highland ny
    If I had it to do over... Install a 30amp 240 volt outlet that matches your charger plug, not the dryer outlet, unless your dryer is in the garage near the car.
    At the ESEV link above, they also have adapters to go from dryer plugs to charger plugs.
    My recommendation would be to install the 240v as close as possible to the charge port. Get the dryer adapter, and take it and the charger with you on trips. The 120v can charge it overnight, but you may find a 240 outlet on a trip, like to a relative's house, and it may be a dryer type. You may only have an hour or two somewhere to charge. Never hurts to get a charge.
  3. Cordycep
    Cordycep Junior Member
    Elk grove
    i notice the new nissan leaf 2018 evse charger, it connect directly to dryer. rated 32A. Would that work on the prime?
    Andyprius1 likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I believe so, I put 50 Amp CB. At 220V and 6.2 KW so I= Power(watts/ E or 6000 Watts/220 Volts = 27.3 Amperes of current. Your 32 Amp CB should be sufficient.
  5. TalkWrench
    TalkWrench Junior Member
    Rhode Island
    There over 20 companies making public charging stations, are they all approved?
  6. TalkWrench
    Rhode Island
    That score is totally stupid and useless. "Good HVAC settings" They were off, that's not a setting. One trip I got in the vicinity of 115mpg for a 38 mile trip and it it gave me a score in the 60s. 123mpg "Good steady driving" score of 64. It goes on and on this was on my 16 Prius 2.
