Please help making weird buzzing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josiah De La Rosa, Dec 19, 2022.
  1. Josiah De La Rosa
    Josiah De La Rosa New Member
    LA
    Hello my Prius has been making this sort of buzzing noise kinda sounds like it’s behind or in the main hybrid snyergy drive. It’s making this sound every 2 to 6 seconds when driving and park or in idle what do I do ? Does anyone know what this is
  2. Josiah De La Rosa
    LA
    Here is the video [​IMG]
  3. Tombukt2
    Tombukt2 Senior Member
    13,823
    2,509
    Durham NC
    Possibly brake system . I think no videos till a few posts make it through.
  4. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    It is likely the brake actuator sounding the death knell.
    Do you have any trouble codes to share?
  5. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Have the car in ready mode while listening to the noise. Now press the brake pedal firmly several times - quickly. Does the sound become more frequent or continuous?
    If it does then the noise is the pump inside the brake actuator assembly. The actuator contains the pump, hydraulic valve block, and other bits in one "you have to replace the whole part" & is leaking internally (quite badly) and is well on its way to complete failure.
