Please help me diagnose this
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Feb 27, 2020.
  1. Mendel Leisk
    42,271
    m.wynn and ATlam like this.
  2. ATlam
    ATlam Member
    64
    57
    San jose
    Thank you Mendel :) do you know how long I can keep ignoring this problem and keep on driving ?
    It looks like replacing the gasket or engine is more than what the car is worth itself. As a lifelong fan of Toyota's reliability I'm disappointed that i couldn't make it to 300k miles.
  3. ATlam
    ATlam Member
    64
    57
    San jose
    It was leaking into the cylinder but not the oil in my case.
    m.wynn likes this.
  4. Mendel Leisk
    42,271
    Leaking into cylinder can lead to bent piston arm, since the coolant won't compress. I would confirm coolant in cylinder (with boroscope and/or leakdown test) and get on it soon.
  5. Mendel Leisk
    42,271
    Clogged EGR and intake is likely cause: makes engine run hotter.
  6. ATlam
    ATlam Member
    64
    57
    San jose
    Yes sadly! I bought the car with 172k miles and didn't know about the EGR issue until 50k miles later. I did get it cleaned and all other maintainance but it was probably too late.
  7. ChapmanF
    18,959
    Is there some go-to thread on this topic on PriusChat, the one that says how much hotter, measured by what methods, published where?
    I know it's reposted like everywhere, I just haven't found the place that looks like anything besides a reposting yet.
    2012 Prius v wagon 3 likes this.
  8. Mendel Leisk
    42,271
    I don't think so. But it's accepted lore that introducing exhaust gas displaces oxygen, reduces combustion temps?
    Just googling, a quote:
    When the air/fuel mixture in an engine is burnt at a very high temperature, greenhouse gases such as nitrous oxide tend to be produced. By reducing the combustion temperatures through the use of the EGR valve, this is reduced dramatically without having a significant impact on the efficiency of the truck. In the end, the presence of the EGR makes your truck more environmentally friendly.
    Found here:
    How Do You Identify Problems Associated With The EGR Valve? | Pacbrake
    And this:
    In internal combustion engines, exhaust gas recirculation (EGR) is a nitrogen oxide emissions reduction technique used in petrol/gasoline and diesel engines. EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. This dilutes the O2 in the incoming air stream and provides gases inert to combustion to act as absorbents of combustion heat to reduce peak in-cylinder temperatures.
    At the outset of the wiki article:
    Exhaust gas recirculation - Wikipedia
    Raytheeagle and Grit like this.
  9. ChapmanF
    18,959
    Right, but again, my question was about the quantification, and the strength of support for linking it to HG failure. I'm not even being skeptical, merely curious. The necessary work may have been done, and there may be someone who knows where or by whom and can cite it. I don't mean my curiosity to come across as a challenge to anyone who doesn't, but just to open a door for someone who does to respond.
  10. Mendel Leisk
    42,271
    One hope: keeping on top of the EGR cleaning, will that keep the blown head gasket "wolf" at bay? Stay tuned... :)
    pjksr02 likes this.
  11. ATlam
    ATlam Member
    64
    57
    San jose
    Shop gave me a quote today. It was either $1000 for head gasket repair or $3050 total for engine and labor. This car has 266k miles and I'm wondering whats my next big repair will be. Should I just get a gasket and drive a few more years or should I get the used engine?
    Engine has 97k miles .
    #31 ATlam, Feb 29, 2020
  12. Mendel Leisk
    42,271
    Have they diagnosed head gasket failure, done a leak-down test, or just going with the codes? That's very likely the issue, but still...
    At least run a boroscope in through the spark plug holes, look for coolant?
    Both those quotes are reasonable, but I'd assume both would be the bare-bones approach.
    For example with the head gasket that's the only gasket they'd replace, and that wouldn't include a machine shop going over the head, replacing valve seals, cleaning/checking.
    And the engine swap a salvage, likely with more miles than yours. And would they pre-emptively do the head gasket on that one, or at least leak-down test it?
    But maybe that's ok, in particular the head gasket route, get's you on the road, and finger's crossed good for another 100K.
    Do completely clean the EGR circuit and intake manifold. And look into oil catch can.
  13. ATlam
    ATlam Member
    64
    57
    San jose
    The engine they have used has 97k miles on it, pretty low for a ten years old car. I have not done any of the testing but the mechanic agreed with me that I need the head gasket replaced. He said he has already done a few head gaskets on these Prius.
    I like my Prius, I would love to own another but the 2016 prius is way out of my price point at the moment. I might look into a used similar year Avalon or RAV4 in the future.
  14. Mendel Leisk
    42,271
    Yeah they exist. Our 2010 currently has 86,000 kms, roughly 54K miles.
    Good luck with your repairs. Again, I think it's the clogged EGR that's killing head gaskets, just have to keep on it.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Theres no proof that the miles on the engine are really 97K miles or not. They can slap an arbitrary mileage driven sticker and it doesn’t have to be true. Bring the devil advocate reading from others experience
    Cosmo Tigato likes this.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
  17. Mendel Leisk
    42,271
    Yeah leak-down test is not really something owners normally need do. A shop that's advocating head gasket repair should also have the competence to do leak-down. It takes a particular set of gauges and some know-how, but it's not that involved. Or at least boroscope inspection, look for coolant atop the pistons.
    I get the sense he went in, said "I think my head gasket's bad", and they responded "we can fix that".
    Ultimately, it'll hopefully work out, but it's a little sketchy...
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Cha-Ching for them
  19. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Yeah, I bought a used Engine with 90 something thousand miles on it (yeah right) I showed up with a bad head gasket.
    Just Bought a 2012 For $700 with a Blown Head Gasket | PriusChat
    :ROFLMAO::ROFLMAO::ROFLMAO:
    Grit, ATlam and Mendel Leisk like this.
  20. Mendel Leisk
    42,271
    For that reason alone, the head gasket only repair might be better option. A new engine is a new variable.
    m.wynn, ATlam and Cosmo Tigato like this.
