Please Help Prius 2004 MFD Very Slow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusProudOwner, Jun 14, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    A clogged egr pipe would give you a check engine light and not the check hybrid system warning.
    Did they read the codes once the inverter got replaced?
    Have you checked the hv battery fan?
  2. PriusProudOwner
    PriusProudOwner Junior Member
    71
    they told me that it must be the cables they found dust and salt
    Raytheeagle likes this.
  3. PriusProudOwner
    71
    i just recived aphone call from toyota mecanics they ar telling me everything is fine only the engine is over heating so
    i have no idea vhat to do nov
  4. audiodave
    audiodave Active Member
    800
    272
    US
    Well the radiator can transfer heat from each other. There not totally separate. Thermostat not working correctly?
  5. PriusProudOwner
    71
    i have to change the engine i have 2 choices a 2010 152k for 2400$ or a engine 2014 220k 2000$ vhat should i chose
  6. audiodave
    800
    272
    US
    PriusProudOwner likes this.
  7. PriusProudOwner
    71
  8. audiodave
    800
    272
    US
  9. audiodave
    800
    272
    US
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Has anyone read this thread from start to finish?
    #150 TMR-JWAP, Oct 13, 2018
  11. PriusProudOwner
    71
    third gen 2010
  12. audiodave
    800
    272
    US
    Posted in the second gen.
  13. PriusProudOwner
    71
    i changed the engine completely its on its way to the new owner
  14. bisco
    52,634
    i was checking in to see how the slow mfd cure was going(n)
  15. PriusProudOwner
    71
    its going great changed it to a new one what i do not understand is why are there people on this trend just to stir up trouble walk away find something else to do god
