Please Help! Shaking but already cleaned EGR
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cgcope1, Aug 2, 2019.
  1. Mendel Leisk
    42,194
    What does "MIL" mean, like in "MIL ON with Diagnostic Trouble Code". Guess I should know, but stumped.
  2. JC91006
    16,925
    8,636
    Malfunction Indicator Lamp
    Raytheeagle and Mendel Leisk like this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    MIL= mother in-law or malfunction indicator lamp, both of which are bad news.
    Peter123, Raytheeagle, Grit and 2 others like this.
  4. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    I guess the used one might be not broken? Hey sorry to make light, but the valve is known to be problematic and you can't usually tell from looking at it whether it is good. As you've seen, posters here usually have good luck cleaning it or replacing with an eBay unit. It's sold as an "assembly".
    A new one through a Toyota reseller for $242 vs. a "genuine new" one on eBay for $200, or a local dealer one for $342 MSRP are reasonable options. Do verify the part fitment in case my search was too hasty.
    My impression on the manifold TSB is that it relates only to startup rattle. I personally haven't seen posts here where replacing the IM fixed an ongoing rattle, but I guess it could happen? Good luck!
  5. Mendel Leisk
    42,194
    I'd guess the replacement intake manifold had 1 into 2 into 4 EGR passages, vs the old style 1 into 4? There's a marginal benefit in that, and it's new (clean). Still I think you'd be back to status quo before long.
  6. JC91006
    16,925
    8,636
    Unfortunately this is at the stage where you just start replacing parts and hopes one of the parts actually fixes your problem.
  7. wheezyglider
    247
    178
    SF Bay Area
    Yeah a new IM would be no-doubt-about-it clean -- and if someone had missed cleaning those EGR inlets it could make a difference. Particularly since they've proven here on PC to clog very unevenly due to that ganging issue you describe Mendel (and which that Gen4 teardown article you posted once specifically addressed, finally fixed I hope).
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    You do the deed yet to put that plan into motion:love:?
    Or other priorities have precedence at this point :whistle:.
    The Critic likes this.
  9. cgcope1
    cgcope1 New Member
    Atlanta GA
    Ok so an update. I bought a brand new egr valve from toyota and just replaced it. Once again it ran fine for about 5 miles, then pulling off at a stop sign it did the shake and partial loss of power for a couple seconds, then the engine caught and was fine. I have driven it 20 miles now and it seems to have helped but not fixed the issue. It does it a lot less than before (it seemed like every time before though it might just be in my head).
    Does anyone have any other ideas? I'm not sure when the spark plugs were replaced last. Also I did have a code for a bad coil pack after a really bad shaking episode about 3 months ago but toyota checked it and said it was fine.
    To recap I've cleaned EGR pipe and cooler and replaced egr valve and gaskets. I also cleaned IM and all the little egr holes in there too. I have replaced pcv as well. Anything big or obvious i'm missing?
  10. cgcope1
    cgcope1 New Member
    Atlanta GA
    I forgot some stuff. Toyota technician was going to do a compression test i asked for, but said he was pretty positive it was not a head gasket issue. I did not really understand his reasoning for this as this mechanic thing is very new to me.
    I also drove it home from the dealership with the egr unplugged again. My house is about 6 miles and I did not have any shaking problems in that short drive. That makes me think for sure it is still something with the egr system but i'm not sure whats left to do.
    I don't have any check engine lights so I'm not sure what to check next. I thought maybe I should drive it around for a while with the egr unplugged to be positive that it does not ever shake with it unplugged, but toyota warned me about driving it while unplugged.
    Thanks for all the help so far though! I did luckily save around 1000 bucks replacing the egr valve myself just to find out paying toyota all that money to do it wouldn't have worked anyway.
  11. Mendel Leisk
    42,194
    Not that I can see, at least not with the EGR. You've cleaned everything, and replaced-with-new the one item with electronics and moving parts. And yet, unplugging the EGR to drive home, no problems. A puzzle.
    Maybe disconnect the 12 volt, wait a good minute, reconnect and try another test drive. Do have everything connected when you reconnect. And be prepared for a little rev-up on your first drive or two after, just within the first minute of engine start up. Seems like the car needs to reestablish some stuff, and rev up is part of the process. That's been my experience, after disconnecting 12 volt for brake work.
    Grit and Merkey like this.
  12. JC91006
    16,925
    8,636
    Well whenever I get the shakes, I solve it with a bottle of Pepto Bismol
    Mendel Leisk and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Pepto’s for the runs:eek:.
    Whenever I get shakes, I need a straw;).
    The Jack in the Box non-fake variety are best(y).
    JC91006 likes this.
  14. JC91006
    16,925
    8,636
    Back to the serious business at hand, did you say you didn't replace the plugs yet?
    So if you disconnect the EGR and run it without computer interference, it's fine. Whenever I get engine issues with it not running right, I always look a the throttle body and the air flow sensors (MAF?) After cleaning/replacing the items, you should disconnect the 12v battery like Mendel mentioned to reset the computer and let it learn everything again.
    When you cleaned out the intake manifold, did you replace the gasket?
  15. wheezyglider
    247
    178
    SF Bay Area
    EGR doesn't kick in until the car is completely warmed up. 6 miles might not be enough to do that. In fact 6 miles might not be enough to even run in closed loop if the engine was completely cold. (Refresher: When the engine is cold it runs "open loop" and doesn't rely on sensors. Closed loop is when the computer relies on feedback from the air/fuel ratio sensor as well as the MAF and other sensors, but it needs the coolant and sensors to be warmed up first. EGR needs that PLUS the catalytic converter to be warmed up. )
    One way to know what state you are actually testing is to use techstream or an OBD2 adapter. But I think it's safe to say if you drive on the freeway for 10 minutes you can be pretty sure that EGR preconditions are met and that your tests using the EGR connector will be valid after that. If you just want to test open vs. closed loop, maybe 5 minutes of freeway is enough to be certain of closed loop operation. You can then force open loop by disconnecting at the MAF, and return to closed loop by reconnecting the MAF. Big changes in behaviour at the transition between closed/open loop or between EGR/no EGR are valuable clues -- especially if they are repeatable.
    Looking back through the thread history -- have you been keeping an eye on the coolant level? What reason did Toyota give for being so certain there's no headgasket issue?
  16. cgcope1
    cgcope1 New Member
    Atlanta GA
    Yes I put a new gasket on when I replaced it. I just replaced all 4 spark plugs too.
  17. cgcope1
    cgcope1 New Member
    Atlanta GA
    Yes but it’s been very hard to monitor because I have taken apart the egr parts 3 times to clean and last time replace in the last few weeks. Each time I have drained the coolant so after a few days of driving again I top it off once it all gets circulated through. The problem is I haven’t monitored it more than a week or so because I’m taking it apart and draining the coolant again to try to fix the egr.
    I can’t remember why, he just said the technician was almost positive it wasn’t a head gasket issue and it was 150 bucks for the test so he said he wouldn’t recommend me doing it.
  18. cgcope1
    cgcope1 New Member
    Atlanta GA
    So another update. I was wrong and partially led everyone astray here trying to help. I drove about 15 miles yesterday with the egr unplugged and after about 10 miles the shakes happened. It also happened one more time a few miles later so I plugged it back in.
    So maybe the problem is not with the egr at all. I brought it to O’Reilly to get diagnostic as I don’t have a scanner yet and I had the obvious egr code because I had it unplugged earlier that day. I also had a cylinder one misfire again and it showed a past history of 4 or 5 of them.
    I believe that was the same code I had a few months ago and Toyota said the coil pack was bad but after testing it they said it was fine.
    So I replaced all 4 plugs last night and drove it about 10 miles and it got the shakes again once at the end. This makes me believe it is still not the problem, but since it’s only happened once I’m not convinced for sure it’s not fixed either. I’m having my wife drive it today to let me know if it happens again as I’m at work all day today.
  19. cgcope1
    cgcope1 New Member
    Atlanta GA
    This makes me think it may have nothing to do with my EGR. Anything else I should do. All I had was cylinder 1 misfire. Should I replace all the coil packs too?
    I’ve changed oil, and it looked fine.
    I haven’t noticed a coolant leak but I will pay more attention this time and hopefully not have to drain it again.
    Is the cylinder dirty or getting stuck or something at low rpm? Can I put some cleaner through my fuel system?
    Please please don’t tell me it’s a head gasket ;)
  20. JC91006
    16,925
    8,636
    The mystery of cylinder 1........I don't want to tell you it's a head gasket
    Raytheeagle likes this.
