Please help with my 2007 Toyota Prius, No Mechanic has been able to help me. ! :-/
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by justinashouri, Jun 3, 2016.
  1. justinashouri
    justinashouri New Member
    Hey guys I bought a 2007 Toyota Prius from a local used car dealer about 2 years ago with 150,000 miles on it. When I first bought the car it had (I believe) the tire pressure light (!) on, and was averaging roughly 36- mid 40's MPGs. Well after driving the car for a bit (about 6-9 months later) the Red Triangle with ! in the middle came on along with a check engine light. My mechanic told me it was the catalytic converter (and can be an indirect sign of a dying battery) but it can be ignored and is still drivable. Well I have continued driving the car until now, averaging about 36 MPG and recently the hybrid warning system light came on (a red car with an exclamation point in the middle illuminated on the top left corner of the dashboard). On a side note the Red Triangle has stayed on consistently (my mechanic told me its related to the check engine/catalytic converter but I think he may be wrong) but after one day realizing my car's oil was EXTREMELY low (almost bare bones if not bare bones dry, literally less than 2500 miles after getting a synthetic oil change) I added 3 quarts at an auto zone and the light temporarily turned off, but since has come back on. I notice my car is using oil sporadically (no leaks), some weeks i need to add an extra quart with very little driving and other weeks I don't have to add any oil after driving a lot (i was told this is due to the catalytic converter not operating properly).
    As it stands right now the car has 170,000 miles on it and I have 1) the tire pressure (!) light, 2) check engine light (catalytic converter), 3) red triangle with exclmation point (i still haven't been able to figure out what this light means, other than low oil due to catalytic converter failure/-> the car eventually burning oil) and 4) the hybrid system warning light with the red car with exclamation point in the middle of it in the top right corner of the dashboard screen. 5) car is burning oil sporadically?
    I honestly have never seen a Prius with this many problems and am thinking/am hoping they are all interrelated, = weak battery from purchase -> low mileage -> catalytic converter failure -> oil consumption not being used properly (missed oil change) -> burning oil more, more frequent oil changes.
    I am thinking I need to dump the car, mostly because no one can help me get to the bottom of what is going on, and there still is the transmission/transaxle that can fail on me as well as the engine. I want to keep this car and drive it to 250k + miles but i feel thats not a viable option without putting in a new engine (as well as the overdue hybrid battery?) due to the fact its burning oil now?
    Any thoughts, opinions or criticisms welcomed/appreciated!
    52,891
    welcome to priuschat!(y)
    you need to find a hybrid mechanic who can read the codes, or take it to a dealer. the warning lights really only tell you that there is a problem, and you need to read the codes. your mechanic sounds like a mench.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Where are you in CA? There are several good independent Hybrid shops in CA.
    JeffD
  4. JC91006
    16,939
    8,647
    You need to get the codes read and keep an eye on the oil level. What city are you in?
  5. justinashouri
    Well my mechanic read the codes, the 1s he mentioned to me were, he just couldn't tell me what the red triangle was, but i am taking it to the mechanic again this week to double check codes: 1) Catalytic Converter not operating properly 2) transaxle not operating full efficiency 3) weak battery
    Wow, thanks for the quick replies guys. Ok, I will get the exact codes this week and am keeping an eye on the oil level daily. Anybody have any idea based on experience or maybe some guesses on what I can expect from my car moving forward? I am really bummed out thinking I am even going to have to sell it at all, really wanted to drive this car to 200k+ miles..
    and I am in Glendale located in Los Angeles.
    #5 justinashouri, Jun 3, 2016
  6. bisco
    52,891
    how much money do you have saved up?
  7. JC91006
    16,939
    8,647
    Your mechanic needs to have a proper code reader for the prius, or you can buy the minivci cable from Amazon and do it yourself when needed.
    If the triangle is on, there is definitely a problem. With a possible catalytic problem and battery problem, that would run you $5000+ in California.
    I can possibly read the codes for you tomorrow, I'm in the Pasadena area at 10am
  8. justinashouri
    Oh wow, 5k + :-(, the car is barely worth that. Yeah i may take u up on reading the codes? I have zero in savings right now. Is my best bet just to get rid of the car? What do you guys suggest? Am i lucky its even driving right now? Im really upset and stressed about this mess I'm in.
  9. JC91006
    16,939
    8,647
    Send me a pm and I'll arrange with you. See if you have cheaper options. I'll be at the rose bowl. Is the car salvaged?
  10. bisco
    52,891
    driving isn't the problem, it's the smaug test.
  11. justinashouri
    it passed smog last time around so I'm not worried about that as long as the car keeps driving.
    #11 justinashouri, Jun 3, 2016
  12. JC91006
    16,939
    8,647
    You paid someone? Should've spent the money on a proper repair
  13. S Keith
    S Keith Senior Member
    799
    331
    AZ
    2003 Prius
    Ever since Bard, smaug hasn't been a problem.
    uagent, Merkey and bisco like this.
  14. justinashouri
    who is baird? i need a new guy! any tip or experiences with my car guys? the reason i never got a proper repair is because i thought the car can operate properly without taking damage ignoring the catalytic converter & the battery was tested weak recently but told to me i can continue driving it. I just don't want the car to break down on me on the highway but i don't want to throw a bunch of money into repairs if no one can tell me whats wrong and why before, because we all know mechanics don't give guarantees.
  15. jjdemu
    jjdemu Junior Member
    39
    IL
    There would be no proper way of telling you which way to go till we get the codes your car is giving. Once we have the codes, these guys can give you what options you have. Your best bet would be a get a minivci cable as mention above with a laptop that is compatible with it and read your own codes. Also there may be some members that is close by you and can read the codes for you.
  16. S Keith
    799
    331
    AZ
    2003 Prius
    Smaug is the name of the dragon in The Hobbit. Bard is he who slayed Smaug.
    Smog is what cars get tested for.
    You've been given all the advice you're going to get. Read the damn codes. You have no idea how many people come on here typing a wall of text without bothering to do a moment of research. Nobody here can diagnose lights on your dash without codes. Some symptoms can be diagnosed as likely the cause of dash lights, but only reading the codes can confirm it. There are a dozen computers in your car willing to give you information and tell you what's wrong. Ask it, not us.
    It's been recommended you buy a MiniVCI. That and other code reading options in my signature.
    wrprice and jjdemu like this.
  17. bisco
    52,891
    have you contacted luscious garage?
  18. bisco
    52,891
    are you saying there will never be a sequel? can a dragon really die?(n)
  19. S Keith
    799
    331
    AZ
    2003 Prius
    You know California is a big state, right?
    He's about 6 hours from Luscious.
  20. bisco
    52,891
    hey, when you out california as your location...
    kenoarto likes this.
