PLEASE Help
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Annella, Mar 14, 2017.
  1. Annella
    Annella New Member
    Ft Lauderdale Fl
    I'm a new owner of a Prius C 2013. I've had the car less than a week & today this problem has reoccurred 4 or 5 times. When I turn the key I get my welcome I'm on bubbles & the dash board lights ( I attached a picture ) all stay on. When I go to put into reverse the dash tells me to put the car in P position to start. I turn the car off & I get the "see you" & it turns off. I start it again & it starts fine, sometimes taking 2 or 3 attempts before it starts normally. Sorry if I'm wordy I'm new to this forum also. Any help is greatly appreciated.
  2. JaredSJLY
    JaredSJLY Junior Member
    28
    US
    Your foot wasnt all the way on the brake when you turned the key. This is normal, you just have to have your foot on the brake then turn
    Annella likes this.
  3. Annella
    Annella New Member
    Ft Lauderdale Fl
    Thank you very much for all your input & suggestions. I went out this morning & it didn't do it.
    Thx
  4. jscoot
    jscoot Junior Member
    25
    23
    PDX
    Mine has the push-button start, but I have had the same thing happen. Coincidentally, I've also had it about a week.
    I've found that if I shift into reverse too soon after hitting start, even with my foot on the brake, it will refuse to start.
    So the sequence is this:
    Foot on brake.
    Start car.
    Wait for car to finish booting up. This only takes a couple of seconds, but it's definitely more than we're used to with a normal car.
    Shift into reverse or drive.
    Go.
    jerrymildred and bisco like this.
  5. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    I have the 2015 Prius c two. I never have to start the car with my foot on the brake pedal. I suggest reading the owners manual for the proper starting procedure for your car.
    XT830C ?
  6. bisco
    52,763
    you can't start a prius without your foot on the brake. any car for that matter, it's a required safety interlock.
    jerrymildred likes this.
  7. pvt
    pvt New Member
    17
    Prescott, Arizona
    2016 Prius c
    From what I've seen in the manual, it's not ready to go until it says "Ready" on the dash. Same with my previous 2008 Prius.
  8. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    The system took far longer to get to READY on older models of the Prius.
    On the C it's really quick - but it's still possible to start the car and shift to drive before it's READY if you're too fast.
  9. pvt
    pvt New Member
    17
    Prescott, Arizona
    2016 Prius c
    Yeah my last Prius really taught me to chill out, put on my seatbelt, check mirrors, drink a cup of coffee before putting it in R or D :D
  10. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    When I turn mine on, I wait till the dash has completed its boot up and wait until the gas engine has started and ran for 30 seconds before placing in drive. Just checked, I can turn the car on without foot on brake.
    XT830C ?
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    THIS. Happens to me all the time.....when I get in a hurry.
    Step on the brake; WAIT for the green key symbol on the dash, then push the button.
  12. JaredSJLY
    28
    US
  13. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    I haven't had this issue with my Prius C but I also have an actual key, it's much easier to remember than the FOB
  14. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I get that message when I leave the door open and shift. It seemed random at first , sometimes restarting worked. Sometimes it took multiple tries. It all depended upon the door. I never connected the door until I read about it on this forum.
