Please list your tips for better MPG in the winter.
Discussion in 'Gen 3 Prius Fuel Economy' started by AdrianMBrown, Dec 13, 2011.
  1. AdrianMBrown
    AdrianMBrown Prius Owner Prospect
    16
    Seattle, Washington
    Hi all,
    I've read some forums and there is alot of info on why MPG is worse in the winter and all that, but what I would like to know is how to improve it! I am getting between 40 and 42 MPG on my 2 week new Prius. The temperature has probably been above freezing, but below 45 F the whole time. I do not have a Garage to park my Prius in, and I don't even understand what this "Blocking" stuff is.
    So can you offer tips on improving MPG in the winter? I would really love to see 50 MPG for the first time on my car :(. Would letting my Engine warm up (by idling) before I drive it help? That is not something I currently do because I assumed it would hurt fuel economy.
    Please help, be a Prius Genius!
  2. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Engine blocking is merely blocking the lower grill on the car. I went to a local hardware store and purchased some round, black foam insulation (pipe insulation). The smaller sized stuff (1/2"? or 3/8"). I cut some lengths that would fit across the lower grill and wedged it in there. It didn't fit as well as I liked, because there are some plastic bars that run perpendicular (up and down) to the grill. I resolved this by cutting little "slits" into the piping so that the slits would line up and fit in with the vertical slats.
    Basically, it deflects the air and reduces the amount of cold air getting into the engine bay. This allows for the car to warm up more quickly and maintain heat better because you don't have as much cold air cooling the engine down.
    While I don't have the same mileage I was getting in the summer (62 - 63 mpg) I'm doing a lot better than I was this time last year (my last fill up was 59 mpg, last year, under the same conditions, it would have been 55-56 mpg).
    Don't forget to check you tire air pressures. They will decrease with the colder weather, so you'll want to pump them up again. I run mine at MAX PSI in the front (44 PSI for my tires) and 42 PSI for the rear. This helps with rolling resistance issues.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. walter Lee
    1,126
    376
    Maryland
    NO SPECIAL SKILLS REQUIRED
    1) Scrape off the frost/ice from your front and rear windshield
    manually with a plastic auto windshield ice scraper and use
    the front windshield defroster and rear windshield defroster
    only when necessary and then so sparingly. Avoid using the
    cabin heater for the first 20 minutes.
    2) Rather than warm up the car for a few minutes before
    driving it - if the windshields are clear and driving conditions
    permit - immediated start your trip and drive once you start
    up the Prius - however, donot push the Prius beyond the
    HSI eco mode during the first 3 to 6 minutes - allow the
    ICE to gently warm up while the Prius is moving forward to
    its destination for the first 6 minutes.
    3) Park your car to get the maximum sunlight exposure during
    the winter with your front windshield facing east in the mornings
    and south in the afternoons - this maximizes the suns warming
    up your windshield so you dont have to put on the defroster.
    4) If you can - drive during the warmest part of the day and
    avoid driving when its cold if you can.
    5) Combine all trips less than 4 miles/20 minutes together
    during the day - driving each trip in sequence with the longest one
    first and the shortest one last making sure that the time between
    each trip is less than 15 minutes of the last.
    6) Keep your speed under 53 mph, for best fuel efficiency keep
    your speed between 23 mph to 46 mph. Driving longer than 40
    minutes per trip tends increases your fuel efficiency while driving
    less than 40 minutes per trip tends decrease your fuel efficiency.
    7) keep your Prius trunk empty ( keep your payload as light as
    possible especially over the rear tires).
    8) Avoid driving in wet/rainy, icy or snowy road conditions
    ADDITIONAL WORK REQUIRED
    1) Raise your tire pressure to 42 psi front/ 40 psi rear.
    2) block your lower air intake grill as a previous replying
    poster has suggested when the outside temperature is
    less than 50F.
    MAJOR INVESTMENT REQUIRED.
    1) install Toyota's optional electric 400W engine block heater
    onto your Prius. Plug it into a wall socket for 30 minutes to 90
    minutes before you drive. After it warms up your engine coolant,
    remove it and drive off. The Engine block heater cost about $60.
    The installation if professionally done is the major expense ($$$)
    but it can be done as a DIY if you have the time, energy, and
    skill ( a heated garage or a nice warm day in the parking lot helps).
    The ongoing electricity cost to heat up your engine and whether
    the FE savings is worth the cost is one of debate. From what
    I've read Engine block heater last from 3 to 6 year.
    2) Learn to hypermile with a ScangaugeII. The ScangaugeII
    cost $160 normally but the bigger investment is in your
    time and effort. While hypermiling can achieve over 20%
    better fuel efficiency than the EPA, it usually requires that
    Prius must be driven slower than what most people are use
    to and adds about 25% more time to your travel time.
    For a second opinion/resource
    A Hybrid Owner’s winter survival guide - CleanMPG Forums
    FWIW: MPG improves over time because the stock Prius
    tires' rolling resistance will decrease over time - New tires
    cause a 5% to 10% reduction in MPG for the first few
    months.
    hope this helps
    Walter Lee
    (aka "HyperDrive 1" on Cleanmpg.com)
    2010 Toyota Prius III , Blue Ribbon/Dark Grey, oem floormats
    Yokohama Avid S33D (front 50psi/rear 48psi)
    ScangaugeII(Fwt ,SoC, GPH, RPM)
    100% grill blocking
    Odeometer +17800 miles
    overall 61 mpg
    Worst Tank 52mpg (Winter, Dec 27th 2010)
    Best Tank 70mpg (Fall, Sep 29th, 2011)
    Last tank (Dec 8th, 2011) 63 mpg, 17835miles, 636 miles using 10 gallons of E10 87oct gasoline.
    Spooled, Threej and cwerdna like this.
  5. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Regarding #1, some people use windshield covers to avoid having to scrape ice. Having covered or garage parking helps too. When I had covered parking at my apartment, the car that was covered had a clear windshield while the other didn't, if it got to freezing outside.
    Regarding #5, yup, this is always a good practice in general... if going to the shortest destination first, stopping, then the next and so on, the ICE may never finish warming up and is constantly wasting fuel in warmup mode.
    Scangauge II athttp://www.amazon.com/dp/product/B000AAMY86?tag=priuschatcom-20 is now down $118. I posted about it in another thread but it was $118.85 yesterday.
  6. bisco
    52,863
    wear a heavy coat, hat and gloves and leave the heat off!:D
    Danny3xd and Grit like this.
  7. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    Some of us can not avoid driving daily on ice / snow. When temps are minus, just get used to the idea that fuel economy will be less.
  8. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
  9. hill
    9,041
    You can do a lot to keep mpg's high in the freezing cold - but slush, rain, snow ... there's no way to prevent the drag that those elements cause. Those are mpg reducing things that can't be prevented.
    only the lower grill? Maybe for YOU that works, but when it comes to grill blocking that's not all that some do.
    In addition, a few of us got Toyota thermostats (from Japan) that run a few degrees warmer. That helps a bit too, along with all the other trick that have been posted ad infinitum.
  10. fuzzy1
    10,714
    What is your average trip distance? Due to engine warmup needs, short trips are not good for MPG in any gasoline car.
    I live in your region but was out of town the first half of this month. As my MPG graph shows, past Decembers have produced the worst MPG. Summer will be much better.
    You are new to the Prius, so you still have a lot to learn. And if you were not already a hypermiler, you have even more to learn. Refer to the already-mentioned winter survival guides both here and on CleanMPG.
    For the very best results, you will also need a ScanGauge or other engine monitor, though this is overkill for most drivers.
  11. walter Lee
    1,126
    376
    Maryland
    wowsers! That's a bargin! :)
    My first one cost me $160. My second one (now on loan to a FEH with an intermittent ABS problem) cost me $125...I really do miss my second one... I am soo tempted to get a third.... :D
  12. justJacque
    justJacque New Member
    council Bluffs Ia
    Four Touring
    what site did you go to to get the thermostat from Japan? And was it a coolant thermostat or a heater thermostat?
  13. hill
    9,041
    Coolant. One of the members here on PC brought a bunch over (from japan), many years ago, for the gen3 reveal in Detroit.
    Wow! That was a lot of years back ... just like this thread
  14. Abarnabe
    Abarnabe Active Member
    172
    102
    Netherlands
    I know it's an old post, but I'm searching a gen3 thermostat with opening rated to 88C /190 F, is there a part number or any link available?
