Please tell me I'm crazy! (brake job)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doogster, Apr 11, 2012.
  1. doogster
    doogster Junior Member
    65
    OK. Local mom and pop shop told me I needed new front brakes and rotors and wanted $211 total for the job... or, if I bought my own pads and rotors then just $59.99 for the job + tax.
    I went on to Amazon.com and found some highly rated AC Delco pads and rotors for a total of $71.35 delivered! Perfect... the total job would cost me $135.54 for pads and rotors... and that is a bargin price, as far as I'm concerned.
    Got the work done on Monday morning... guy said it was the easiest rotor and brake job ever.... in and out in 30 mins.
    Ever since then (well, its only been a few days) it SEEMS like my MPG are slightly lower than I'm used to.
    I always got 48.0 MPG on my ride to and from work... yes, sometimes a little more and sometimes a little less... but by the time I got to my destination (either work or home) the display would read 48.0....
    Now I can't seem to get it above 47.4!
    Am I crazy?!?
    I have no warning lights on...
    Is this my imagination?
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah, it could be. A 1.2% reduction is not very much, so it's a pretty tight call. There could be a tiny bit of brake drag until the pads bed in. Keep driving it and see what happens, it's certainly very minor if indeed there's anything in it at all.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Try putting the car in Neutral and braking to a stop from 40 mph several times over the course of a drive.
    If it still seems to be a problem, then jack up the car and see if the front wheels turn freely. It is possible that you have a stuck caliper, if they did not take the time to lubricate the slide pins. Check the back wheels too, even though presumably they did not work on them.
    Grocery Boy Jr likes this.
  4. doogster
    65
    If the brakes are rubbing... wouldn't I hear something from them when the pedal is not depressed?
    ...and... if they are in fact rubbing slightly.... might it "wear in" after a short time?
    Just askin'
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    This.
    It's possible they didn't clean, or properly clean, the caliper pistons and then pushed them back into the bores to make room for the new, thicker brake pads. That accumulated grime can cause the pistons to stick thus not allowing the pads to fully retract away from the rotors and causing drag.
    Telling signs would be more brake dust residue on the wheel, noticeable drops in mpg, and as mention above, spinning the wheel off the ground.
  6. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    If the calliper is not free to slide every time you use the hydraulic brakes the calliper will apply both pads to either side of the disc but will only release one side causing it to drag, and wear one pad more quickly.
    Jacking the car up and rotating the wheels will soon show if there is a problem.
    You will not hear a noise with new shiny discs.
    One thing that could cause you to loose MPG, did you change the front wheels from side to side and are the tyres directional. (If the tyres have an arrow on them are the arrows pointing in the direction that the tyres normally rotate)
    John.
  7. doogster
    65
    I don't know if the tires where swapped or not... I wasn't there when the brakes and rotors were done.
    There don't appear to be any direction arrows on the tires...
  8. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Anyway, remember that a 1.2% drop in FE is very little, so there's still a very good chance that this is just random variations. Definitely track it for a bit longer before worrying too much about it.
    BTW. Have you checked you tire pressures?
    Grocery Boy Jr and xpcman like this.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Most disc brakes have some light drag, but can be designed to minimize this (using seals that pull the piston back a little).
    It's possible that the new pads have a slightly higher coefficient of friction (to improve pedal feel) than the OEM pads. It's also possible that the drag is slightly higher with the newly machined rotors.
    Feel free to go ahead and check things, but be aware that you may hear a rubbing sound of pad on rotor and that it's probably a normal thing to hear.
    I'd give it a week or two to see how it goes as the pads get burnished in.
    - Chris
  10. doogster
    65
    wow... I will say the pedal is definately different since the new brakes and rotors... it seemed like before just touching the pedal would almost launch you through the windshield... very touchy... now, its much easier to apply the brakes gently... might that have something to do with it?
  11. Britprius
    5,194
    1,922
    The only time you should notice a difference is when you brake in an emergency since the hydraulic brakes are only used then, or below 7MPH above this regen braking is used.
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    My experience with brake jobs is that the brakes are a little less responsive before they're bedded in. They'll probably get a little more aggressive with time.
