Plop plop sound from tires - but not a flat!
Discussion in 'Gen 3 Prius Main Forum' started by JBarleycorn, Jan 22, 2020.
  1. JBarleycorn
    JBarleycorn Junior Member
    Driving my 2012 Prius this morning I heard a plop-plop-plop sound from the rear. It starts at around 12-15 mph and speeds up as the car accelerates. It sounds *exactly* like a flat tire. But when I look at the rear tires I see nothing wrong. Tire pressures are at specification.
    The tires are Goodyear Assurance FuelMax installed June 2017. They have about 24000 miles on them.
    Any thoughts?
  2. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    Something stuck in the tire or tread?
  3. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Is there a nail or screw in one tire? Wheel bearing? Warped rotor?
    Could be a few things. Drive in a parking lot and have someone along side and look and listen....
  4. fuzzy1
    10,722
    Have you inspected the entire circumference of the tires to discover any possible foreign objects lodged in the tread?
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    If it isn't something in the treads, once I had a stone in the metal hub that would drop and sound like that as the wheel turned at slow speeds. It finally fell out (and I found it - pea sized only), but I did a lot of head scratching before that because the treads were clean.
  6. JBarleycorn
    I didn't see anything in the tread, but I need check again in better light.
    What would be the indication of a warped rotor?
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Tire probably bulged on the inside, had that happen to me before. Tires were about 7 years old at the time and I scraped the cement bump thing at the store parking lot that tells you to stop pulling forward in the parking space.
  8. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    If the sound goes away by itself, it may have been a flat spot from being parked too long. It happens.
    dig4dirt likes this.
  9. bisco
    52,891
    rotate the tires and see if the sound changes
    JBarleycorn and ASRDogman like this.
  10. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I will add a possibility: You may have the beginning of tread separation between the outer layer of the carcass or belts and the inner layer of the carcass. You usually cannot see the bulge at rest, but when moving the separating spot flies outward a bit and then flops into the pavement as it comes down , causing the “plop” sound. If that goes on for a while you may see a slightly more worn spot in the tread where it is plopping against the pavement, but it is extremely dangerous to drive a tire that is having carcass layer separation as the stress at highway speeds can cause a sudden total separation and blowout. That has happened to the car I was driving and to a semi driving directly in front of me. In both cases the tire throws chunks of tread and the belts out in all directions and then the carcass explodes as it is too weak to hold the pressure. Please have it checked.
  11. ASRDogman
    8,070
    4,092
    A wheel weight might have come off. Are they stick on ones?
    Grit likes this.
  12. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I'm also leaning toward this theory/guess. The bulged sidewall on mine was on the inside sidewall,never knew it was there till the tire shop told me it needed to be replaced.
    kc5dlo likes this.
  13. Robert Holt
    1,313
    890
    That’s a possibility, but for me losing a tire-balancing weight has resulted in a weird vibration that would maximize at some lower speed like 30, but then decrease until hitting a higher multiple of that speed like 60 where it would increase again. So the vibration would not increase linearly with speed like the tread separation “plop” thing tends to do. That said, when you have two dynamically out-of-balance tires in the front, they can get “in phase” with each other at certain speeds , and in the Mazda I had with that problem the steering wheel would rather quickly shake so violently that car would become essentially directionally uncontrollable—very unpleasant.
    Raytheeagle likes this.
  14. bisco
    52,891
    a repetitive scraping sound as the rotor and pad rub
  15. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    And it should pulse the brake pedal if you stop on mechanical brakes (switch to Neutral before you brake lightly),
  16. JBarleycorn
    Thanks for interesting suggestions.
    I was hoping it was a flat spot on the tire, because it first happened on a very cold morning after I hadn't driven for a couple of days. But the sound is still happening so I don't think it's a flat spot.
    I don't hear any odd sound or feel any pulsing in the brakes, so I don't think it's the rotor. The car doesn't pull to right or left, and there's no vibration at highway speed. Not sure how to check the wheel weights ... It sounds awfully loud for a wheel weight.
    I guess I will rotate the tires around and see if anything changes, and/or look at the wheels while someone drives around in a circle. Then I guess I'll have to take it to a shop ...
  17. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I had some Goodyears that made a sound but there were pretty old. I tend to not rotate tires so they can stay on the rear without much wear for a long time.
  18. jburg
    jburg Member
    93
    RTP, NC
    I would check the play on your hub bearing. Jack up the car and see if there is play in the wheel. I would put money on that.
  19. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    wheel bearing?
  20. Mendel Leisk
    42,373
    Maybe pop the wheel off and have a real close look.
