Plug-in battery 4.4kw SOC Values
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RonnyK, Apr 6, 2016.
  1. RonnyK
    RonnyK New Member
    Sweden
    Hi
    I have a 2013 PIP and have Torque Pro app installed. When I charge my battery full +8 Culsius/46 Farenheight in my garage. I reach a SOC of 84,7% and when driving so it is depleted it remains 23,9% then EVmode ends.
    When charging again back to 84,7% I get 2,46kw back in to the battery
    Is this OK ?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Hello. Using an aftermarket app or gauge is a great way to learn more about how the system actually operates. There are many things to monitor and a wide variety of conditions which influence output.
    In this case, you are seeing the "longevity" range for the SOC (state of charge). The system doesn't allow charging above or discharging below those levels. That charge/usage span is what ensures the longest lifetime for the battery-pack. That's why it last so much longer than other rechargeable devices, like your phone.
    RonnyK likes this.
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Yep, that's about right. The system keeps the battery charge between about 20% and 80% to extend the battery service life. That's about 60% of the nominal 4.4 kWh capacity, nearly what you measured during recharge.
    RonnyK likes this.
  4. RonnyK
    RonnyK New Member
    Sweden
    I have read some ware that when charging it's possible to add about 3.3kw and I only get 2.46kw, what to think about that ?
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    As the battery ages its capacity is reduced. I only measure the full charge amount occasionally. The largest for a full range charge was 3.1 kWh when the car was new and the most recent measurement was 2.7 kWh. My total miles are just above 20K.
    RonnyK likes this.
  6. RonnyK
    RonnyK New Member
    Sweden
    Okey, mine have 37500 miles, Do any one know if temperature can have an impact on charge level ? My garage is about 46 Fahrenheit but outdoors the last 4 months, sins I bought the car has been about 5 degrees Fahrenheit.
    Can the battery get more kw when temperaturs are warmer ?
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    SOC range is normal. It takes about 3kWh to fully charge with about 15% loss.
    NortTexSalv04Prius and RonnyK like this.
  8. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Yes, temperature has a lot of impact. In summer you can easily have 30% more EV range than in winter. Part of this difference is because the battery takes more charge then. You can find some data about variation over time within the year and over years here: Electric battery degradation | Page 3 | PriusChat
    #8 Jan Treur, Apr 6, 2016
    RonnyK likes this.
  9. RonnyK
    RonnyK New Member
    Sweden
    Thanks, this was a good tread. I will read it thru today and probably learn alot.
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I don't know the exact figures, but there will be some inefficiency in converting the voltage and storing the energy.
    RonnyK likes this.
  11. john1701a
    12,840
    5,312
    58
    There is also a hit taken caused by freezing temperatures. Electrical resistance is increased then in lithium chemistries.
    #11 john1701a, Apr 9, 2016
    RonnyK and Rebound like this.
  12. RonnyK
    RonnyK New Member
    Sweden
    I found this picture on the web telling that at 80 % should be around 235volt, I have 221volt at 84%. witch according to this picture are around 60% What does that tell ?
  13. bisco
    52,863
    i didn't realize the voltage changed with charge level.
    RonnyK likes this.
  14. CaliforniaBear
    1,180
    289
    Northern California
    Some do more than others. Quote from this web page Measuring State-of-charge - Battery University
    "Each battery chemistry delivers its own unique discharge signature. While voltage-based SoC works reasonably well for a lead acid battery that has rested, the flat discharge curve of nickel- and lithium-based batteries renders the voltage method impracticable."
    RonnyK likes this.
  15. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    In my 2012 PiP, when I'm at 20% SOC (4 visible battery bars), the battery pack voltage reads 200. This is with no load on the system (A/C is completely off, no headlights, etc). I've seen the battery pack SOC as low as 18% (2 battery bars visible), at which point the ICE kicked in and starting charging the pack. I do not recall the pack voltage at that point. I have seen my battery pack voltage as low as 183 volts while going uphill just after the car exited EV mode and entered HV mode and SOC was 23.1%. I seem to recall that when I've charged the car overnight, my SOC is usually 85% and the battery pack voltage level is 225, but I will confirm that tomorrow morning.
    RonnyK and bisco like this.
  16. devprius
    devprius /dev/geek
    979
    291
    SOC this morning was 84.3% and 223 volts.
    Potorap and RonnyK like this.
  17. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Well SOC for me last time this year was 85.49% and this morning, 85.49%. The data is interesting and graphing it can show some interesting correlations:
    upload_2016-4-12_20-3-59.png upload_2016-4-12_20-5-19.png upload_2016-4-12_20-6-45.png
