Plug-In battery life?
Discussion in 'Prime Technical Discussion' started by Max Wu, Apr 26, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Makes sure any light components that condense and are a liquid get knocked out or caught prior to entering the intake;).
    This along with cleaning the egr circuit is thought to help improve the chances of avoiding a blown head gasket. I had the OCC installed on our 2010 for 30k miles and I did catch 8 ounces of “spooge” in that time:eek:.
    Now with thengine running less and kicking on at freeway speeds, I’m thinking it is prudent:).
    But open to ideas (y).
  2. Mendel Leisk
    42,364
    The Positive Crankcase Ventilation system (PCV) tends to dump oil/water/gas oleo into the intake manifold. If you look down through the throttle throat and see a glistening reflection, that'll be it. Removing the throttle body will afford a much better look.
    An Oil Catch Can, aka Oil-Air Separator, is patched into the hose between PCV valve and intake manifold, with the object of trapping the vapor before it it gets to the intake manifold.
