plug in battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Desertdeals69, Aug 26, 2020.
  1. Desertdeals69
    Desertdeals69 Junior Member
    44
    23
    Lk Havasu City Az 86403
    How to change a plug in battery
    52,848
    unbolt the battery case, get some big strong friends or an engine hoist, and have at it!
    you're in missionary territory, all the best!(y)
    (service manual probably details the procedure)
  3. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Ok, I'll byte which battery ... The little guy in the corner or the big honkin one?
    bisco and jerrymildred like this.
  4. Desertdeals69
    44
    23
    The big one.
  5. bisco
    52,848
    uge, really
    make sure to disconnect the safety plug
    Yea Right likes this.
  6. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    #desertdeals69 your profile shows Gen2 Prius. Is that the car you are asking about? Does it have a plug to charge the traction pack? If yes what kind of plug?
    If you're asking about a different car, what car are you asking about?
    If it's just a regular gen2 prius than that shouldn't be as difficult as it would be if there is a plug to worry about too.
    Prodigyplace likes this.
  7. Desertdeals69
    44
    23
    I gave my wife the 09 and now I'm driving a 14 plug in. On a full charge the dash indicates 11.1-11.6 miles. 6 months ago it went as high as 13.4 miles. One difference is the air temp. It was 50-70 degrees in Dec to 91-117 degrees in Aug. I have 137,000 miles on the car. I just bought a complete battery from a 2015 with 67,000 miles and was just going to try it out. I am familiar with gen 2 batteries because I own 4 gen2s and have cycled and matched modules on 6 packs.
    vvillovv and bisco like this.
  8. bisco
    52,848
    your battery is normal. i would suggest it is a (very labor intensive) exercise in futility.
  9. vvillovv
    4,337
    1,518
    NY
    I'd be very interested in any and all you're willing to share, if and when you do the pack swap.
    I had a 14 PIP for a couple years and still remember some of the differences between the prime and its
    predecessor the PIP. I was the 350 something member of the blizzard brigade here at PC. I can see myself attempting a Prime pack swap one day in the distant future, possibly. if I live that long.....
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Turn off the AC, then check the estimated range ;)
    And remember it's an estimation based on previous journeys, it is not a useful indication of battery SOH in the slightest.
    dbstoo likes this.
  11. vvillovv
    4,337
    1,518
    NY
    go look at techstream. I'm sure hoping you've heard of it.
  12. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    My PIP maxes out at 10.6 miles. I am very conservative driver.
  13. bisco
    52,848
    you need a new battery :cool:
  14. vvillovv
    4,337
    1,518
    NY
    There are plenty of trick one can use in a PiP to up the EV estimate. And one has to describe their own definition of conservative driving in detail for context. I agree that an guessometer topping at 10+ EV miles is
    awful. In my 14 I used to get 12 in the coldest days of winter. But I would also drive in creephome mode 5-8 mph for a mile than under 35 for another mile to get the electric components warmed up sufficiently to keep the ICE from switching on at single digits F degrees and lower.
    ie describing how you define conservative driver is important.
    PA Prius and jerrymildred like this.
  15. QuantumFireball
    420
    269
    Ireland
    Anything over 10 is good for me :)
    Totally depends on driving conditions and other factors. And as I said, not a reliable indication of battery health.
    jerrymildred likes this.
  16. PA Prius
    762
    251
    SE Pennsylvania
    True. For me it means tires at 46/44 psi. Not using a/c. Slow acceleration. Anticipating stops so to use brakes as little as possible. Choosing secondary roads over highway. Driving below the speed limit when traffic allows, around here that generally means about 40 mph. Reminding the drivers behind me that the speed limit sign is for maximum, not minimum.
  17. bisco
    52,848
    i average 14 in decent weather, just tootin' around town, it's a great little errand runner
  18. vvillovv
    4,337
    1,518
    NY
    QuantumFirebird and Bisco are better references than I am. With my PiP I wanted to learn all the EV I could absorb and had the 999.9 mpg bug all the time. So the computers were filled with EV only miles and reflected that data on the gauges each time the car was driven.
  19. Desertdeals69
    44
    23
    I was only commenting on the reading after the charger shuts off. From 13+ TO 11.1 8 months later and 45 degrees warmer. I understand the ac uses some batery. I have a route that I do many times and there is quite a difference in mpg if I make all six lights or have to stop. I have another battery so I will change it out when it cools down to below 100.
    Yea Right and bisco like this.
  20. bisco
    52,848
    if possible, document the whole job with pictures and commentary, that would be very helpful to the community, as some will likely need a new battery in the future.
    cookprius and Yea Right like this.
