Plug-in Charging System Malfunction message
Discussion in 'Prime Main Forum (2017-2022)' started by bb4srv, Sep 4, 2018.
  1. sylvaing
    sylvaing Senior Member
    1,221
    517
    The battery is air cooled and with a 200W heater element to warm it up. Why does running the ICE help warm it up?
  2. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Ok, in very cold conditions heatpump struggles heating the cabin.....where the ICE comes to play...heating the cabin thus the traction battery.
    #42 Louis19, Aug 25, 2023
  3. sylvaing
    1,221
    517
    Oh true, the battery vents are in the cabin so heating up the cabin helps heating up the battery.
    Louis19 likes this.
  4. myselfnjit
    myselfnjit Junior Member
    33
    Update on the MIL.
    Toyota replaced the charger assembly and it has worked as it should for a month now. It has been cooler out so next summer should be the real test, when charging in the summer sunshine.
  5. sylvaing
    1,221
    517
    Whenever it was a sunny day and needed to charge, I opened the windows so the interior would not get too hot. Sending 50C air to the battery instead of cooling it down is not a good idea.
