Plug-in hybrids losing market share
Discussion in 'Prime Main Forum (2017-2022)' started by Northerner, Nov 16, 2020.
  1. Northerner
    Northerner Active Member
    121
    103
    Midwest
    2020 Prius Prime
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Articles like that are how narratives come about, since it neglects to look forward.
    We all know the rollout of RAV4 Prime began after that data was collected, but many referring to it will not. They'll just see the headline & graph, then make an assumption it was proper journalism... rather than just a website seeking participation with at-the-moment hot topics.
  3. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    I’m not sure I understand your meaning. We might expect the RAV4 prime to reverse the plug-in hybrid trend, but it will not alter the past. Do you feel the graph is made up?
    I’m as much surprised that hybrids and electrics both increased together while the plug in hybrids declined. For myself, at least, I consider the Prius Prime to be the perfect transition car as the auto industry moves to all-electric in coming decade(s).
  4. john1701a
    12,840
    5,312
    58
    The graph gives an impression decline will continue. We've seen sources like this in the past used for undermining.
    With the initial huge demand of RAV4 Prime., there's no reason to expect that to continue... but that critical tidbit was omitted... which is the approach antagonists use to mislead.
  5. Zythryn
    Zythryn Senior Member
    6,411
    4,411
    I suspect the downtrend happened as a result of the Volt being discontinued as well as the hesitancy of Toyota to expand sales of the Prius Prime.
    The RAV4 Prime should indeed help increase market share of PHEVs.
    Northerner likes this.
  6. Trollbait
    12,814
    Introduction of the Escape PHEV had also been delayed. Though BEVs do generally outsell PHEVs. Last year they made up 74% of plug in sales in the US for 2019, and the California numbers from the article are showing the same ratio.
    U.S. BEV And PHEV Car Sales Compared: 2019
    For the curious, the European market ratio is closer to 50:50, but BEVs still lead.
    EV-Volumes - The Electric Vehicle World Sales Database
    The headline states it was for the first half of the year, and the CNCDA report isn't about future trends.
    Are you calling for data based analysis to have speculative info added in order to fend off propaganda? Doesn't that just turn a news article into propaganda?
    Those that will this for ill will do so regardless of what other tidbits it would have.
    Zythryn likes this.
  7. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    I see plug in hybrids as the gateway drug to cleaner more efficient cars. I think it will make sense for many years until we build up a charging infrastructure. I am having as many family members as possible try my car out to get a taste of electric drive. So far they have been impressed and surprised by how smooth and zippy the car is. They expect it to be slow and dull which its not.
    Zythryn likes this.
  8. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    All one needs to do is think about what type of vehicle the majority of Amtericans like to drive, than figure out
    how many PHEV's are built like that. Than figure out how many EV's are built that way.
    It doesn't take a Niccolo Machiavelli mathematician or a theoretical astrophysicist prof to run those numbers.
  9. bisco
    52,803
    can someone throw in a gasser line on that graph please?
    of course, it's california, home of disneyland and imagineering
  10. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That article was addressing sales in California. I live there and I can tell you that the reason for the drop off is a total lack of advertising for the PHEV concept. I don't know anybody who understands the concepts behind a PHEV. Most think that the Chevy Volt was a BEV. The Ford C-MAX by ford was not advertised as a PHEV. I was surprised to see the one across the street plugged in a month after they bought it.
    My neighborhood is not typical. There are lots of Silicon Valley workers living here so a lot of BEVs and hybrids of various designs too. Within 6 houses of mine are 3 hybrids 3 PHEV, two BEV. It's not unusual to pull up to a stop light and see nothing but EV of one type or another.
