Plug in Prius or LEAF?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cireecnop1, Apr 12, 2012.
  1. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    My local Toyota/Mitsu dealer just got one of these.
    $31k sticker and about the geekest thing I've ever seen. Rear wheel drive!
    "Based on independent EPA testing, the Mitsubishi i can travel 62 miles on a full charge, in typical driving conditions. Incidentally, the EPA's MPGe ratings came in at 126 City and 99 Highway for a combined 112 MPGe—making the Mitsubishi i the most efficient electric vehicle in its class."
    Might be the first real production EV in N WV ever. No Nissan dealer close by.
  2. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Get the Pip, reason: flexibility. Citywide power outage, no problem, extra cold weather and bad headwinds, no sweat. Need to make a sudden drive from work to a 3rd destination no problem.
    The Leaf is a fine short distance commuter vehicle, but that is all it is and with the length of your commute that's all it can be.:D
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    The MiEV is just too cartoony for me, I couldn't deal with the constant egg jokes!:rolleyes:
  5. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    Would that mean if the outlet(which is just a plug under a parking lot light) is only 8amps, the Leaf will refuse to charge? Does the "trickle charger" that comes with the car auto reset if there is a fault?
  6. cireecnop1
    338
    Pueblo, CO
    It would be "Real Time".
    I work the swing/night shift, my car will be home from 4am-at the latest 4pm. I should be using current sunlight. :rockon:
  7. cireecnop1
    338
    Pueblo, CO
    That's still in the back of my mind. I'm hoping I can convince the Nissan Dealer to let me borrow the car for a day or two, just to get a feel for what I would need to sacrifice, if anything.
  8. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    An article in today's New York Times reports that a Leaf charging off the Colorado electric grid emits as much greenhouse gas as a gasoline car getting 33 mpg, because of Colorado's high dependence on coal.
    So one might think that the greenest choice is to get a PIP and only charge off your solar panels, not at work.
    That's probably correct, although it's more complicated than it looks. Your solar system is tied into the grid, so it'll be replacing dirty electricity independent of your power usage. In other words, as far as location is concerned, you're charging with the same mix of clean and dirty power at home and at work. (Granted, your solar contribution could reasonably make you feel entitled to 100% of the green good karma.)
    Getting back to the big picture, Colorado's power mix could still vary depending on the time of day. At home you could use the timer to charge in the wee hours, when demand is low. Your civic-minded utility might only be running its cleanest plants. More likely it's running the cheapest ones, which could be coal. I wonder if you can find out.
    If nighttime power is cleaner power, then your greenest solution would be a PIP that you only charge at home. If and when Colorado utilities deliver a greener power mix, you could start plugging in at work.
  9. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Colorado also has many good renewable options, you don't have to wait for the utilities to provide it, you can buy the greener mix and help drive the utilities to deliver a greener mix. The OP can purchase wind-energy which is particularly plentiful at night. You might even be able to get wind-energy at work as the incremental costs may not be that much.
  10. cireecnop1
    338
    Pueblo, CO
    That was an interesting article, but they didn't really make a fair comparison. When comparing the Leaf to the Mazda 3-- which one is greener when taking into consideration the drilling/refining/transport of oil/gas?
    Another point to think of is when the electric load begins to increase, the utilities will be forced to build new plants under stricter emission standards. So using coal to power your electric car for a short amount of time can be looked at as a good thing. :p
  11. cireecnop1
    338
    Pueblo, CO
    :mad: Pueblo county/Blackhills unfortunately doesn't have that option.
    Blackhills has to increase their green options so they are offering rebates to Purchasers and Lessees. SolarCity is taking care of me with a 20 year lease on a 3.6kw system. :rockon:
    I guess Blackhills gets to claim that as 'their' solar power that I am agreeing to buy. . . .:rolleyes:
  12. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    They said it was a "well to wheels" analysis.
  13. cireecnop1
    338
    Pueblo, CO
    "The U.C.S. report, which takes into account the full cycle of energy production, often called a well-to-wheels analysis, demonstrates that in areas where the electric utility relies on natural gas, nuclear, hydroelectric or renewable sources to power its generators, the potential for electric cars and plug-in hybrids to reduce carbon dioxide emissions is great. But where generators are powered by burning a high percentage of coal, electric cars may not be even as good as the latest gasoline models — and far short of the thriftiest hybrids."
    They way its worded they are talking about the electricity generation , not necessarily gasoline.
  14. drinnovation
    2,027
    586
    65
    CO
    Hmm might need to look into that. The 2007 Colorado law (House Bill 1281)
    that doubled the state’s renewable energy portfolio standard (RPS) also required municipal utilities to offer an optional pricing program that allows retail customers to support emerging renewable energy technologies through voluntary purchase programs.
    Maybe blackhills got an exception until their new wind plant comes on line in 2012 (i.e. this year).
    In a year or two they should be at 30% renewable even if you are not buying it directly.
    And yes they will get to claim the solar you are "buying" to meet their RPS goals.
  15. evfinder
    evfinder Member
    293
    72
    I've just been reading the UCS draft report. The report goes into detail ad nauseum about how they calculated the CO2 emissions from electricity generation but gives no details about their values for gasoline except to give a number of grams per gallon burned. Looking at the number it does look like they allocated a pretty good amont, almost 50% of the amount derived from direct burning, for downstream emissions.
    The way the report is formated can easily lead to someone getting the wrong idea. There is a heading that reads "
    About 18 percent of Americans live in GOOD regions—where an electric vehicle has the equivalent global warming emissions of a 31 to 40 mpg gasoline vehicle, making some ​
    gasoline hybrid vehicles a better choice with respect to global warming emissions." The problem is that the last part of the heading, "gasoline hybrid vehicles a better choice with respect to global warming emissions." appears on the top of page 19 making it look like that is the whole heading for that section unless you read things carefully.
    Here is what the report says.
    1. 45% of Americans live in a region where an EV produced less CO2 emissions than the best hybrid vehicles.
    2. 37% of Americans live in a region where an EV produces about the same CO2 emissions as the best hybrids.
    3. 18% of Americans live in a regions where an EV is equivalent to a gasoline car with 31-40mpg fuel economy so the best hybrids are a cleaner choice in these regions.
    4. There are no areas of the country where electric vehicles have higher global warming emissions than the average new gasoline vehicle
    Noel
  16. cireecnop1
    338
    Pueblo, CO
    I haven't read the entire report, just blogs and news articles referencing quotes from the report.
    But I have yet to see where they compare Oil drilling, Refining, Fuel Transport, Fuel Storage, then MPG directly with Coal Mining, "refining"?, Transport, Power plants, then MPGe's.
    Its a little one sided to compare the full life cycle of coal with the simple number of MPG's as if gasoline spontaneously appears in our tanks.
  17. evfinder
    evfinder Member
    293
    72
    They use the Aragone National Labs GREET model to figure out how much CO2 is produced by burning a gallon of gas and that supposedly takes into account all the CO2 produced by drilling, pumping, shipping and refining oil. The trouble is that they use one figure but just as electricity generation various by region so does the preparation of gasoline. For example Colorado uses a lot of Canadian tar shales as the starting point for crude extranction and this is dirtier than most oil sources.
  18. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    And not just CO2 but CO2e - the total greenhouse gases expressed as an equivalent amount of CO2.
  19. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    I'd vote leaf, but decide which car you would rather be in, that's a lot of car time. You might want to test drive the volt at the same time, all your work miles would be electric but some denver miles would be on gas. You drive the right amount of miles for a plug in no matter what you choose.
  20. austingreen
    13,714
    4,232
    Austin, TX, USA
    The problem with GREET is they use old numbers. You can ponder your navel or get the real numbers from your utility. The key to me would be even if there is slightly more CO2 contributed by you with a plug-in than a prius, you are still doing better for the environment by using less oil the scarcest energy resource, and better for the country by using north American energy that is not prone to OPEC blackmail.
