Plug-In Prius: real winter driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Nov 12, 2012.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    We do tend to get a few -20F below and one to two -30 below every year. Does not make it any easier when it comes tho! :)
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Just plugged in. It has warmed up to 3°F.
    Obviously, the engine started the moment the car moved.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    It still uses the pack more than your prior Prii, though right? By running lower RPMs, other things being equal, and getting assist from MG2?
  4. john1701a
    12,840
    5,312
    58
    Far more. Seeing a 20 MPG boost (despite the extreme conditions) makes that quite obvious.
    With my 2010, the same drive would have yielded results around 40.
  5. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    It was -39 with the windchill here yesterday. I suppose after a certain temperature, fuel economy isn't as much of a concern as keeping warm.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    At -39 deg F, I will be glad that the heater is running with waste heat from the gas engine.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    went to work this morning at 7 am with my trusty dusty Eddie Bauer Winter coat and gloves. No seat heaters, no climate control, no defrost, 15 degrees on Scan Gauge II Fwt. Went a maximum of 16 MPH No ICE cubes.:cool:
  8. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    I think the PiP is really protecting the battery at these temperatures.
    Winter really kicked-in this morning. Today I started the PiP at -25°C (-13°F), -34°C with windchill (-29.2F). My commute is 15.7 miles, mostly highway. The ICE started as soon as I pressed the Start button. I had to wait a couple of minutes to melt the ice frozen on the windshield inside the car. (Yesterday's condensation froze during the night)
    Then, when I reached the highway, the car could not use EV mode at all, even when I released the accelerator. In fact, at some point I realised that the car was not even in EV-Boost mode. The energy arrows were going TO the batteries instead of FROM the batteries. The car reacted like if I was in HV mode. (And I assure you it was not the case)
    When I got out of the highway, EV power became available again but was underpowered. On my return trip, temperature has risen to -18°C (0°F). But same story: EV was not strong enough to be used on the highway. (But I managed to trigger the EV-Boost mode at some point) I used my last remaining EV mile on the last street of my commute just before I got in my driveway. (That mean I managed to use my last EV mile only after 31.4 miles since I can't charge at work) I usually do not have much EV miles remaining on my return trip. o_O
    I did a 51 MPG trip today. My worst mileage ever with the PiP. But at least, the battery was spared by the PiP. :)
    Edsvfr800 and usbseawolf2000 like this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think getting 51 mpg in that cold of a temperature for 32 miles is amazing! :D
    Drake likes this.
  10. bisco
    52,773
    you guys are scaring me.(n)
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    BOO!
  12. john1701a
    12,840
    5,312
    58
    That's the same thing our family in Massachusetts said when we decided to move from there to Minnesota. :eek:
  13. bisco
    52,773
    probably thought you were going to turn into popcicles.:p
  14. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I lived in Rochester NY while attending College. Unbearable cold Winters with the lake effect. Unbearable.
  15. bisco
    52,773
    builds character.:rolleyes:
    JMD likes this.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    or big sno men, or sno wo men:cool:
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    :rolleyes:
  18. bisco
    52,773
    or sno kitties.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    aw:giggle:
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Did you have the cabin heater going?
    PHV battery warms up by drawing air in the cabin.
