Plug-In Prius: real winter driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Nov 12, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    4kw? the useable kw of the PIP is only 2.7kw
  2. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    I have a technical question. It makes sense to warm up your seats before you drive on a cold winter morning and to do that while the charging cord is connected. If you use the timer to charge your PIP and if completes the charge and shuts off will the charger begin again if you use the remote to turn on the AC (in the summer obviously) or seat heaters in the winter?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    4 kW to maintain low speed. PiP battery has about 2.7 kWh usable energy. The max it can put out is 41 kW so it can be drained in about 4 minutes. :eek:
    priuskitty likes this.
    52,878
    unfortunately, no. no provision was made to preheat the car before driving.
    lensovet likes this.
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The cost of electric heater (both for the vehicle itself and the sacrifice to battery-capacity) pushed it beyond the affordability mark. Once the engine warms up, that feature loses its value too. The first time you get stuck in heavy winter-impaired traffic, you'll see that. For short trips, it could be handy. But then again, that's what the heated seat already provides.
    There's the battery-pack itself to consider as well. With electric heating, you'd be taking away EV power to keep you warm. That's a tradeoff many wouldn't be willing to make, but at the same time would be frustrated that both wouldn't be practical.
  6. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    You/we are mixing two different terms here. The capacity of the battery back is measured in KW per hour, aka KWh. It's how much sustained energy it can provide for an hour. In the Prius' case, the total amount of KWh for the battery back is 4.2 KWh, of which we can use about 2.8 KWh. That means that it can provide 2.8 KW for an hour, or 1.4 KW for 2 hours, 0.7 KW for 4 hours, etc. When accelerating in EV mode, the car can use up to 38 KW. So it can sustain that level of use for about 4 minutes. Normal driving in EV mode seems to be around 8 to 12 KW.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    sorry, I knew that, forgot the "h" in KW
  8. lensovet
    2,615
    496
    Burlington, NJ
    nitpick: not "per" hour, but just hour. kilowatt-hour.
  9. lensovet
    2,615
    496
    Burlington, NJ
    no. seat heaters are only on when the car is in READY mode. the car will charge only in ACC, ON, or OFF mode.
    not sure about remote A/C, but this should work, because it definitely does that on the Advanced trim.
    EDIT: I guess the seat heaters will be on in ON mode. however, the car will automatically shut itself off after a minute or two in ON mode, so you can't really preheat it. however, the seat heater on HI makes you pretty toasty in under 60 seconds, so I doubt it would be of much use.
  10. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Thank you for answering my question. Only two more days until I PU my Advanced, Lord willing. I have a Tundra and my seats warm up noticeably about the time I get to work (5min.). I'll have a lot of time to play with stuff in the car on my 800 mile trip back from the dealer.
  11. markabele
    5,084
    1,782
    Nebraska
    You could just put a little space heater in there and start it up 20-30 minutes before you leave. Just make sure it is a newer, safe space heater....not those death traps of the old days. ;)
  12. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Wow... are you in for a treat!
    Enjoy the PIP....:)
  13. nhalber
    nhalber Junior Member
    83
    Marblehead
    Impossible to try and figure out the algorithm for EV mode. In September, I had 165 mpg. Now in November, as it has gotten cold, I am down to 80, same driving pattern.
    Still good, but perplexing.
    I guess that I would like on a 3+ mile trip that it use up all of the available battery capacity first.
  14. lensovet
    2,615
    496
    Burlington, NJ
    Note that the battery has an optimal operating temperature range. If it's too low, that could cause the engine to start up.
    There's an entire page in the manual devoted to conditions under which the engine might turn on even if you have sufficient charge for EV driving.
  15. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Don't forget to really clean your windows, it will eliminate the need for running the window defrosters in many cases.
  16.
  17. GRILL BLOCKING: See post 36
  18. 3PriusMike
    3,101
    2,421
    Silicon Valley
    A lot of people have a problem understanding this. (And people in the non-technical media are constantly using the terms incorrectly). If it helps, you should think of a kilowatt-hour as a kilowatt times an hour...or using a kilowatt for an hour.
    Mike
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    And similarly, "per" means "divide".
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    was 32 degrees on my outside temp gauge in my PIP. Windows frosted, scraped them. Drove to work, all EV no ICE. I wonder what temp has to be for ICE to kick in.
