Plug-In Prius revealed
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by zenMachine, Sep 2, 2009.
  1. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    +1 for the central coast of California!
  2. GeekEV
    GeekEV Member
    417
    NorCal, USA
    Excellent point. I was also thinking that: a) Almost every EV parking space I've seen has the charger up front; and b) in my garage (at least) that position would put it much closer to the dryer's 240V plug, for faster charging? :)
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the plug was probably moved to reduce cost. since charging probably goes through the inverter, the cables are a lot shorter up front. since all the fuses are on the left hand side... cables get even shorter (possibly non existant) on the left side. plus.. more efficient charging... even though these cables probably have just about No resistance. (so back to cost)
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Well, this was revealed in Europe right? So, the plug would be on the passenger side, isn't it?
  5. joe1347
    joe1347 Active Member
    669
    44
    AZ
    Makes sense. Good thinking. You would assume that Toyota would also add some sort of ignition interlock
  6. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    This is exactly where I differ from most PHEV fans. I don't want to drive 20 miles on electric and then switch over to a normal Prius. I would rather the electric be used for acceleration only and gasoline for maintaining speed - from the minute I put the car into drive. I would at least like the option to switch between the two modes. For those that want all electric and no gasoline, they should have the option and for those that want all electric just for accelerating and gasoline for maintaining speed from the beginning, they should have the option. :)
  7. Flying White Dutchman
    4,376
    313
    mm i think you need to tell me where your suitcase is so i can sneek in:D
    but that you forgot you know... did you know your forgot? mm gues you never know... or do you.:D:p
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    TMC to Display Prius Plug-in Concept at Frankfurt Show
    Tokyo — TOYOTA MOTOR CORPORATION (TMC) announces it plans to display the "Prius Plug-in Hybrid Concept"—a concept vehicle that combines the benefits of CO2 emissions-reducing electrical-outlet battery charging and gasoline-electric hybrid vehicles—at the 2009 Frankfurt International Motor Show (IAA) (Frankfurt Show) to be held from September 15 to 27. The Prius Plug-in Hybrid Concept is based on the third-generation gasoline-electric Prius and is equipped with a lithium-ion battery.
    TOYOTA: News Releases > TMC to Display Prius Plug-in Concept at Frankfurt Show
    The EV cruising range is approx 20km(target), according to the New European Driving Cycle (NEDC).
    Ken@Japan
  9. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    83
    Camas, WA
    Doug,
    Any idea if a retrofit will be available? Or will Toyota prefer to boost their inventory of clean certifiable used 2010 Prius?
    Please remember my brilliant suggestion that you use the Priority Prius crowd for US BETA Testers. Together, we represent a fleet, and if you pick and choose, I am sure you could get a more enthusiastic group of BETA data collectors than you would from a utility company, corporation or municipality.
  10. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    there is no way retrofit would ever be available, too many different parts...
    ... I am curious about the cost - as i thought before, they increased the electric top speed so you could use it on short trips exclusivly (i dont ever need more than 100 Kmh in the city), and 20 km range is plenty for me. But again, problem is that if it costs $5k more, there is no way to repay this cost.
    Also since batteries will hold more charge and since electric motors are more powerful, i wonder if ICE mode will actually be more efficient and how much...
  11. hill
    9,038
    Is it schizophrenia that enables one side of the company to say, "PHEV's are not the way to go ... nor are EV's, either" ... while the other side of the company dangles working models in front of us? Or do they just live to torment us.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I wouldn't think so because the Li-ion battery is smaller and more powerful than Nimh. After 20 mile range, gas engine will 'work with' Li-Ion battery much like current car, I should think.
    The 20 mile range must vary depending on driving conditions.
  13. Winston
    Winston Member
    614
    SF Bay Area, California
    I believe that lithium ion batteries are more efficient at converting the energy spent for charging into stored energy. I think the Nimh batteries waste about 30-40% of the charging energy, while Li ion waste only about 5%. That fact would definately make the lithium batteried Prius get better mileage than the NiMh Prius.
    On another note. In the SF Bay area, my "marginal" electricity rate is now up to 45 cents a kilowatt. You heard that right 45 cents. At 25kw per 100 miles (which is what the Chevy Volt is expected to need) it would cost me $11.25 in electricity to go 100 miles. Why would I want a plug in, at that kind of cost?
  14. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    20 km = ~ 12.4 miles.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    I think you mean 45 cents per kwh, and 25 kwh per 100 miles. When does that marginal rate kick in ? When the time comes, you may want to look into night rates. In the meantime, look for conservation opportunities.
  17. Winston
    Winston Member
    614
    Yes I mean kwh, I was just being lazy.
    We just got smart meters that measure energy every hour. I can even log in the next day to get the hour by hour usage online. It is really cool. They have not begun offering rates by time yet. However, I am sure it is coming.
    0-375kw is 11 cents
    375-487 is 13 cents
    487-750 is 26 cents
    750-1125 is 38 cents
    over 1125 is 44 cents
    AC and Pool pump sucks up all my electricity. Plus, 4 kids electronict toys, bleh.
  18. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Because most people can avoid paying that marginal cost by charging at night with time of use metering. Plus at 45 cents and all of the CA solar credits it should pay you to put up solar panels (if you can).
    If none of these solutions are for you... then plugging in wont be a great idea!
  19. hampdenwireless
    1,104
    86
    Baltimore MD
    Toyota will almost certainly not provide that option. Third parties will.
  20. hampdenwireless
    1,104
    86
    Baltimore MD
