plug-in states and ghg
Discussion in 'Environmental Discussion' started by austingreen, Nov 11, 2012.
  1. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Hmmm, sounds like you are anti petroleum - interesting. Then the question to you is - how do you think the Volt was produced? Answer: petroleum. You can not ignore nor escape that fact.
    DBCassidy
  2. dbcassidy
    1,581
    290
    GreenChoice sounds interesting. Problem is, even if you purchase their product over the grid, you can not claim that ALL of your electricity is petroleum free. That would be a very foolish assumption and thought process.
    DBCassidy
  3. dbcassidy
    1,581
    290
    Very good question indeed.
    Your rationalization also applies to the Volt and the Leaf. Both of these cars are bad for the environment, especially in the mid west (coal generated electricity is the norm).
    DBCassidy
  4. dbcassidy
    1,581
    290
    Do you think your Volt was manufactured using no petroleum? (That would be are very green approach to producing the Volt) You would reply, of course not, then the realisation sets in: I can't get away from petroleum in my life. So, even if you use a small amount of gas, or any gas at all, your Volt could have never been built without petroleum.
    Those are the cold, hard facts.
    DBCassidy
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I rely on the national lab data studies. In the end we have to accept that conclusions are best estimates, with inherent uncertainties we can try to quantify.
    That said, I found the coal plant efficiency argument specious.
    Am I wrong to conserve electricity, since it might lead to plant inefficiency ?
    Is your presumed use of wind power causing the same ?
    Unfortunately, the sad state of affairs in the US is that coal plants will only shut down when they are unprofitable. That they go through a transition of further inefficiency on the way to closing is unfortunate but currently unavoidable.
  6. dbcassidy
    1,581
    290
    Coal plants, with the low price of natural gas, could very well shut down due to being unprofitable. Blomberg Businessweek also ran an article concerning solar in the U.S. now with the elections over, tax subsidies, and credits will probably also go away. Natural gas prices and the big energy producers (the investors) could really put a big dent in solar expanding. Big energy sees solar as a threat to their business plan. Also, there is no national streamlined green energy policy in this country when compared to Germany.
    DBCassidy
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yeah, unfortunately the repubs hold green energy subsidy hostage every time budget wars erupt. I perosnally think the right thing for the dems to do is scrap all subsidies, but they have their own special interests to pander.
    In a sane world, we would tax carbon to pay for climate change and all subsidies would end.
  8. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    The best national study I know looking at the impact of marginal loads is:
    http://energyenvironment.pnnl.gov/ei/pdf/Impact%20Assessment%20of%20PHEV%20on%20US%20Power%20Grid.pdf
    Still not very local, and making strong assumptions. They start off by ASSUMING that none of the PHEV load is attributed to renewables, be it hydro, wind or solar. They state
    And for a single car one might be correct in assuming the margin demand does not fill the gap, especially immediately. What they ignore is that with predictable increases from off-peak demand, say from PHEV nightly charging, there can be increased installation/use of renewables such as wind, backed with NG peakers (which they need for day peak demands anyhow). Otherwise the systems owners may not want to add them and let coal/nuke cover the nighttime baseload and just use gas peakers for the day.
    Still the study found that most areas (including you in NM) the PHEV will decrease the average carbon output of their regional grid (since the margin is mostly NG), with the only major increase being for Ca/NV where nighttime charging would have 4% increase in carbon -- but that is just because their grid is already very green. (Note that in keeping the OP, they did model the distribution of vehicles in a non-uniform maner with more in CA/NV but based it as a fixed fraction of registrations, not a "green" based distribution.
    The suggested a "carbon tax" that would help shift the economic model so dispatch is to greener lower ghg sources.
    I was not saying that conserving was wrong, its just that the analysis is complex because when coal plants efficiency are included 1kWh of marginal impact is not just about the source used, but where/when.
    With respect to wind causing inefficiency in coal plants, it absolutely does. There was a recent study by argonee on it
    Government Lab Finds Wind Energy Not Meeting Carbon Emission GoalsInstitute for Energy Research | Institute for Energy Research
    which shows that that GHG impact of adding wind in areas with high coal generation is not a 1-1 gain because of the efficiency lost, e.g. with their model adding 21TWh of wind would only lead to a new ghg reduction equivivelent to a net reduction in coal plant of 15TWh. However, that is still a significant reduction.
    Zythryn and austingreen like this.
  9. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    It is a complicated item, and Colorado is quite different from Texas. This is very rough, and I'm sure groups in colorado have done some real analysis. I don't even try to estimate the estimates for a few kwh, as those are normally determined by the grid rules. Adding wind takes years to filter through the system and give its marginal impact. Let's take a first cut at the macro consequences in Colorado.
    If we look at the data between 2000 and 2010, coal has fallen from 80%-68% of power produced, non-hydro renewables increased from very small to 7% and natural gas provides the rest of the new power. Petroleum has stopped being used, and natural gas is being used in its place in some peaking power stations. Ghg/kwh in Colorado has fallen about that same 12%. Which means first cut, wind is not making coal and natural gas more intense. A high percentage of wind is making it to the grid:) New demand + wind produces very little ghg.
    Unfortunately the numbers have a little magic in them. We find that natural gas is more efficient with wind. This violates our reasoning that wind requires peaking plants to even it out. What really happened is more efficient natural gas plants were added to the grid. Wind and natural gas drastically cut down ghg of the new power added to the colorado grid. We can ask the what if question though, what if we built ccgt natural gas plants instead of wind. That would have also drastically reduced carbon intensity of the colorado grid. We would need to look at the actual grid figures to see how much peaking natural gas was used to even out wind, but most here look at the ghg versus that scenario. With current low natural gas prices, ocgt are being built instead of ccgt which are 50% more efficient, so to even get here we need government regulation or people choosing to pay more. I would say a low estimate of marginal Colorado wind versus ccgt would be 80% of the ghg needed to run the ccgt.
    From the numbers Colorado's coal power plants have about the same carbon intensity with the added wind, increasing only slightly in the fourth significant figure. I would think that given the large amounts of coal, the net effect of wind + night charging won't change efficiency much. When we only look at night versus day charging though, night charging will be slightly more efficient. If smart grid is implemented where the car/grid agree to grid management of night charging then the plug-in fleet can help manage the spikes in renewable.
    Texas has it much easier than Colorado here, as ERCOT is within the state and can be managed to help wind and there is a more flexible natural gas structure. In Texas wind has slowed the growth of coal. In 2018 more coal will be shut down, and much shut during the winter. In CO you are subject to negotiations with other states.
    It costs money and real resources to shut down and restart a coal plant, while it only costs a penalty to idle a turbine. The 5-10 year solution is to replace those coal plants that are at low capacity with fast cycling ccgt power+wind. This takes investment which is available, but regulation to shut some coal capacity. The swap actually will drop fuel price risk, as there is a great deal in colorado for coal.
    With wind being idled what happens is marginal impact/kwh actually increases, but .... Each MW of wind produces fewer GWh of electricity.
  10. austingreen
    13,714
    4,232
    Austin, TX, USA
    I actually have to agree with them there. If we look out at 2030, it is likely most of the wind has already been built because of mandates and/or choice. When we add more phevs at that time they will marginally use variable fuel plants. That means at night they won't be using the old coal plants, hydro, nuclear, etc.
    Now between now and 2030, plug-ins charged at night help determine the grid we are building. Night demand makes it less expensive to green the grid. That is a different issue, than the one they are addressing.
    They assumed a uniform distribution based on all car sales. This is a poor assumption for the next decade, but not so bad going out to 18 years from now. It certainly is much better to do current car sales, instead of electric production that is based on industry and air-conditionaing not cars. California uses 6.9% of electricity, gets 11% of light vehicle sales, but 32% of plug-ins today. It has a number of things going for it to be disproportional. Moderate climate, heavy traffic, and heavy air pollution should keep it high. In 10 years though, plug-ins won't be new, so high numbers of initial adopters won't mater, nor will the large in state incentives. I would not be surprised if california takes an even bigger percentage of plug-ins next year. the Pike research projects about 25% going out in the longer term, but IMHO it will be closer to 20% in 20 years. The assumptions are much better than most I have seen.
    In the US we dispatch Coal, then natural gas thermal, then ccgt filling in with peaking plants often ocgt. The british dispatch method, only requiring regulation dispatch ccgt, then natural gas thermal, then peaking then coal. This would drastically reduce ghg emissions. Some of the switch is occurring now because ccgt fuel costs are now lower than coal, but that can easily reverse.
    Rules - that is different regulation, and/or carbon tax/cap and tax would speed up reduction of ghg from the grid. Senator Byrd (WV) is now gone from the senate, and he had a huge amount of influence to block ghg reduction methods. Mitch McConnell (KY) is now the leading senator working against coal regulation, but he will be less effective without his democratic coal buddy. We can hope in the next decade or so these Coal leaders will have less power.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Posted that in another thread:
    Week's worth of Volt stats | PriusChat
    The Leaf won't meet my range requirements and the PIP doesn't meet my EV range or power/quality of drive requirements even if I could buy one in my state. Full disclosure: ghg comparisons don't register on my purchase decision radar; hence, I don't have a dog in this fight/pissing match.
  12. austingreen
    13,714
    4,232
    Austin, TX, USA
    Seems like the volt is the right car for you as the phv is the right car for usb.
    From your stats and the 2010 average texas grid you produced 201 g/mi, as opposed to the 258 g/mi I produced in my prius. :) YMMV
    Full disclosure, I used average texas grid. I would really need to know your utility and plan to determine your average. Average should stay less than 220 g/mi though. I would also need to know charging time of day and location to determine marginal CO2. Austin Energy is part of a federal program attempting to figure out charging time, and marginal demand, for plug-ins. We should know more in a couple of years.
    fotomoto likes this.
  13. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    Great find, thanks for posting that.
    I agree some of the assumptions are questionable, but overall very enlightening.
    Of course, the 800 pound gorilla in the room is grid level power storage. If that comes to pass prior to 2030 much of this report goes right out the window. It is still good information for current effects on charging and the grid.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    So, 'smart' charging at night just means more coal use, more pollution, and more power plant profits ?
    Who wudda thunk ?!
    dbcassidy likes this.
  15. austingreen
    13,714
    4,232
    Austin, TX, USA
    Duke is putting a 36 MW energy storage system on a west texas wind farm. We should see soon (5 year time frame) how effective it is at buffering, and how battery capacity changes. One of the texas wind ideas is to use the batteries in plug-ins as part of the smart grid. In texas peak demand is 3-7 pm in the summer. You might plug in at work, and the grid would charge up your car, evening out morning demand, then provide power to the grid in the afternoon if wind dies down or demand spikes. Software would allow you to set a minimum battery level. Drive it home, and it would power your home when you plug it in, then recharge at night smoothing out those wind turbines.:) This is 10 year out stuff, but people are working on it.
    Still outside texas, the west coast, and hawaii, I don't think energy storage systems will have much impact.
    The biggest flaw I see with the charts is the high amount of gas thermal plants. These are all old plants, and I hope in the next 18 years these will be replaced with fast cycling ccgt. The ccgt should be at least 50% more efficient. They may be replaced with ocgt peaking plants though which are slightly less efficient, but are much less expensive to build, and would likely be off for night charging.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    So in order to load level demand, and perhaps (PERHAPS) use a greener and more efficient source energy, you are adding two trips to the battery, or about a 30% energy cost.
    Hardly seems worth it.
    The implementation also seems unlikely, since it assumes the *EV owner has a battery willing to contribute juice AFTER driving home.
  17. icarus
    icarus Senior Member
    4,884
    976
    earth
    Confessing to not having read the whole thread,, I would simply add the following. Electic motors are fundamentally more efficient that an ICE under almost all conditions. It is thermally more efficient. Additionally, electric motors can be turned into generators simply by reversing current flow, as the Prius does in regen, such that they can recapture, in some cases significant quantity of the initial energy.
    Finally, electic cars can take advantge of solar and wind when it is available, delaying charging (if possible) until there is excess grid capacity. (the net/net worst contributor to GHG is energy produced, but not used,, the idle spinning capacity for example.). Electric cars can also take advantge of non peak periods to more efficiently use the grid.
    One more thing, in a relly smart grid, the cars can not only buy power from the grid, but also sell it back to the grid at times of peak demand/pricing. A well designed regimen could tell the car, buy power to charge when it is $.05kwh, sell it back when it is .$.10 kwh, but make sure I have enough juice int he battery to get to work tomorrow. (also realize that these cars are likely to be plugged in, 23/7, because most cars are not driven huge number of hours per day.)
    Good day,
    Icarus
  18. drinnovation
    2,027
    586
    65
    CO
    Did you read the report I cited?.. their projections (if you combine distribution of veichiles with data from figure 5) is than in 2030 only about 20% of the marginal impact of PHEV charging at night will be from coal.
    austingreen likes this.
  19. Zythryn
    6,412
    4,415
    Sage, I think you would find some interesting information in the report. You really should read it.
    Charging at night tends to use more natural gas, not coal. Although this does depend upon region and yes, some more coal may be used in some regions, but natural gas is the biggest contributor.
    In addition, if an economic incentive is placed on energy generation, virtually all regions generate less co2 with overnight charging.
  20. icarus
    4,884
    976
    earth
    The thing about thermal plants, unlike hydro for example, is that they cannot be spooled up very quickly. They need to be kept burning at least at a low fire in anticipation of being used. It is the idle, spinning capacity that is waiting for the (often time very short lived) peak load that is the biggest single wasteful emitter. Plug in could have a significant effect on reducing that idle capacity if there were enough of them, and they were programmed effectively.
    We sell ~16 million cars per year in the US in a normal economy. If 25% of them were plug ins, in ten years that would be ~40 million disaggregated battery banks, buying and selling into the grid. All in all, in the net, a good thing.
    Icarus
