Plug n play led headlight replacement bulbs are no good
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Sappy, Mar 30, 2017.
  1. Sappy
    Sappy Junior Member
    Philadelphia, pa
    I put in some led bulbs and it does looks good, but does not light up the road like original oem halogen bulb does in my 2013 Prius
  2. Stephen Ryan
    Stephen Ryan Junior Member
    Wake Forest, NC
    I have the same issue. I ended up aiming the headlights a little higher but this projector lens is definitely NOT made for LED's, that's for sure.
    whitmanrf likes this.
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    they work 'kinda' ok in my wifes subaru forester as hi-beams replacement/
    in my prius: not so much.... :whistle:
  4. 4md
    4md Member
    97
    55
    Sofia, BG
    I read a lot about the LED bulbs and the quality really depends on what chips are used. Decided to try a set with copper belt coolers and Philips chips. They're fine, but maybe a HID kit will light up the road better. Here are some nightly photos with the LEDs, sorry for the low quality, I keep them in a web album where the quality and size are decreased...
  5. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Halogen and HID bulbs create a point source of illumination with almost 360 degree light spread.
    The aftermarket LED bulbs currently all have a circuit board separating 2 LEDs with poor light throw directly forward. This is why a common problem cited for the LED bulbs is poor toward throw, or distance illumination compared to HID.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    In addition, "inexpensive" LEDs just don't have enough light output either.
    Putting LEDs in headlights typically is NOT an upgrade.
