"Plug" running hot....?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by samsdad, Dec 25, 2013.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I did, didn't I? heigh ho, heigh ho, it's off the topic we go!!!!!:LOL:
    52,858
    in the white and drifting snow...:LOL:
    priuskitty likes this.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    what snow? It's sunny and 70 here.:D :whistle:
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Hello Sam's Dad - are you there?
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I was referring to the handle (the j1772 plug), thanks god there is no live electricity there after charging! (or when charging is interrupted by unplugging)
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Sorry to burst your bubble but there is voltage potential at the blue plug (1772) even after charging has completed
    SGH-M919 ?
  7. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    When I say 'live electricity' I mean something that can hurt you or even kill you, what is your definition?
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I wouldn't go poking into the connector to find out but there's about 240 volts ac at the end of the blue plug
    SGH-M919 ?
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    It's a joke, isn't it?
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    No joke I'm serious
    SGH-M919 ?
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Sorry to burst your bubble(n)
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    my bubble's fine:D how's yours?
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    My bubble is tough.
    I poked into the manual and found (what I knew already):
    The CCID... is designed to prevent electrical current from being supplied to the charging connector when it is not connected to the vehicle, even if the plug is inserted into the socket (in the wall - giora)
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    touche. 240 volts still present but no current draw, I'll give you that:D
  15. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Big difference between voltage and current, while there might not be any current flowing the presence of any voltage could cause current to flow, and you could make the path it flows threw, it only take 1/10 of an amp to stop your heart, so don't be the path for current flow!
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I do not agree (although I am not going to actually test it).
    The j1772 becomes live only after it is connected to the vehicle and finished the "hand shake" procedure.
    If you interrupt the charging or when charging is finished, the connector is dead (no live electricity).
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ok, 0k, I'll man up and admit I'm wrong. There's a relay in the brick that connects 240 volts to the blue connector when the PIP charger circuit energizes via low voltage (12 volts?) the 240 volt circuit when the blue connector is inserted into the car's outlet. And immediately disconnects the 240 volts when the blue connector is unplugged. my bad:sleep:
  18. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Sounds good to me!
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    same thing happens at a charging station like ChargePoint, You can hear the relay kick in at a Chargepoint station
  20. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    My Kill-A-Watt registers about 1.2 watt draw (by brick) when car is unplugged.
    Andyprius1 likes this.
