"Plug" running hot....?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by samsdad, Dec 25, 2013.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yeah!
    I am at coffee -17 below going to -0 below for high today keep warm!
    52,858
    16 here, 6-12" coming tonight, the vortex is back!:eek: (thanks for getting us back on track):p
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    And it is going to stay for awhile! Enjoy!!!!! :D
  4. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    15 here and snowing I use ICE this am, heat and defrost!
  5. bisco
    52,858
    good move. i'm heading out with my wife, heat is not an option.;)
    Lourun likes this.
  6. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Be safe and warm!
  7. bisco
    52,858
    thanks! just made it home. slippery with a few inches and coming down hard. 9 degrees, creep and crawl. kept the cabin toasty warm for my bride.:) 23 miles, 61mpg.
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Good Job!
  9. GregP507
    GregP507 Senior Member
    3,002
    481
    In another thread, someone had a pin fall out of the plug. I suspect that was due to a bad connection in the receptacle, causing it to overheat, and the solder and the plastic to melt.
    The receptacle may have seemed fine under lighter and intermittent loads, but hybrid charging is a prolonged, high-current load. Heat can build up, causing damage and even posing a fire risk.
    Get your wiring checked out by a qualified electrician.
