pluggen in Techstream, got some codes!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, May 31, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    Finally got my techstream working, it's a great program but way over my head! But I did get my expected
    P0A80/Replace battery pack and also
    P3019/battery block 9 becomes weak
    P3020/battery block 10 becomes weak
    P3000 battery control system
    Can I assume this just means modules 9 and 10 are bad?
    The other codes I got, in the Braking/VSC section of the computer are
    C1259 HV system regenerative malfunction
    C1310 HV system malfuntion
    No other codes of any kind.
    What say you? Is this a straight ahead battery die-off, or are the last 2 codes telling me someother strange and expensive problem exists in my car? 1310 is obvious. It's 1259 I'm worried about. I'll be googling tonight...
    My symptoms are thus:
    Rapid battery charge/discharge, expecially on hills or just after startup.
    Poor acceleration
    cooling fan doesn't shut off
    ICE doesn't shut off
    And that's pretty much it. Gets me back and forth to work at the moment, but that probably won't last long...
    #1 bmparent, May 31, 2019
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    Could be up to 4 modules total.
    2 in block 9
    2 in block 10
    You should be able to watch the live hybrid battery data and see if there are other weak blocks.
    Skibob likes this.
  3. bmparent
    bmparent Member
    159
    65
    barre ma
    Ah, I was thinking a block was a module.
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    Man, techstream really is amazing. Considering it was 30.00, came in the main in a week and shows me every digit happening inside my car. Just wow. Put that together with all the knowledge on Priuschat. I'm turning into a Prius nerd and it's really fun! Really if I could learn t work on these things for a living, I'd probably do it. I'm fascinated.
    Skibob, SFO and bisco like this.
