Plugin Prius Hybrid Mode ONLY vs Prius 3rd Gen
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by inferno, Jun 25, 2013.
  1. inferno
    inferno Senior Member
    1,072
    405
    Can you guys give an honest answer, without plugging in, how good is your mpg? How does it compare? I feel like the EPA has gotten lazy, especially listing the C-Max as better MPG than the Prius V when real world tests show otherwise.
    So now, I have gotten a lifetime average of 48 mpg with my Prius 2010, through the winters it drops to 40, summers it can get as high as 53 mpg. I hit 58 once.
  2. cosgrove
    cosgrove Junior Member
    44
    Los Alamos, NM
    That's almost identical to out 2010 Gen III trim level 5...
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    EPA lists the PiP as 1 mpg higher on the freeway than a regular Prius. If you click on my Fuelly signature, you'll see what fuel economy I get in HV versus EV mode. I enter them in separately. I average about 60 mpg in hybrid mode.
    However, my HV fuel economy is slightly inflated over a regular Prius because I rarely drive local in HV mode. I use up EV for that portion. Which means almost 100% of my hybrid mode is on the freeway where it is most efficient.
  4. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    Recently went on 400 mile trip only on ice, averaged 58.0 mpg. Very happy.
    mrbigh likes this.
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    No contest, my 2012 PHV clearly delivers better MPG in HV mode than my 2010 did.
    The faster warm-up speed and having a Lithium battery instead of NiMH make a noticeable difference.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Trips down to Las Vegas equal 65 mpg at 65 mph with Cruise Control. I believe that beats everything else on the market
  7. Andyprius1
    2,327
    859
    Cool CA
    As I posted before, I can get 60mpg doing 65 mph driving down to Las Vegas from Sacto with CC. The main problem with a average small commute is, you cannot pick and choose when EV energy will be used. This energy gets used From time to time as the computer(s) determine. You do not have total control. But, overall, the Pip exceeds anything else on the market. As for short trips to the store, it's perfect, in EV . Combine that with a short work commute, charge at both ends and you have the perfect world.
  8. bisco
    52,725
    i get 75 to 80 on the mfd, but i was getting 65 in my 08. i'm a slow and careful hypermiler with little highway driving.
  9. mrbigh
    3,686
    699
    Long Island, NY
    Agree and still have a 2008 (wife) to compare in a monthly basis
  10. Astolat
    Astolat Member
    229
    73
    Guildford UK
    You compare your 2008 wife to your 2012 wife on a monthly basis? Doesn't she complain...? :D
    3PriusMike likes this.
  11. mrbigh
    3,686
    699
    Long Island, NY
    Isn't it neat?...:sneaky:
  12. bisco
    52,725
    but expensive!;)
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    :ROFLMAO: :rolleyes: (y)
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I have a 2010 as well. I see better mpg in my PIP. I think this is (mostly) because I don't do short mpg-killing trips in the PIP.
    I'm not sure why Li-ion vs NiMH makes any difference, other than the kwh capacity.
    Mike
  15. inferno
    1,072
    405
    They supposedly charge and discharge differently. Li-Ions are a bit lighter and more dense. Yeah I think the short trips kill my 2010 Prius. I noticed if I turn the fan off though it behaves a bit better.
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    In particular, LiIon can charge and discharge at a higher rate than NiMH, lessening the need for the friction brakes and increasing regeneration efficiency.
