Plugin - Service Center in Orlando
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by drsacha, Feb 26, 2018.
  1. drsacha
    drsacha Junior Member
    29
    Tempa, FL
    The Toyota website shows no service center for Plugin 2012 in Orlando area. Kindly share address if you know any service center that does services Plugin 2012.
  2. Prodigyplace
    12,718
    11,850
    Central Virginia
    I know Tampa Hybrids in Lutz does Prius service. Todd is well respected here.
    jerrymildred and drsacha like this.
  3. Mendel Leisk
    42,358
    Any Toyota dealership service department?
  4. Prodigyplace
    12,718
    11,850
    Central Virginia
    drsacha likes this.
  5. Mendel Leisk
    42,358
    Also, @drsacha what specific services, say oil changes, brakes, or?
    I'm just not seeing that there's anything that different about doing basic services on a PIP.
  6. bisco
    52,871
    any dealer should be able to service it, whether they sold them or not. they have access to toyota field tech service if necessary.
    jerrymildred and Mendel Leisk like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I was going to say the same thing. I had my fuse recall done at Sun Toyota right around the corner from me. They treated it like it was routine, but PiPs are exceedingly rare around here.
    Mendel Leisk and Prodigyplace like this.
  8. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I had a serious issue with my 2013 PiP and just took it to my regular dealer. (As far as I know there are only two PiPs in town.) And yes Toyota send a tech down to help determine the problem so it could be fixed.
    bisco and jerrymildred like this.
  9. bisco
    52,871
    which toyota website shows service centers? edit, found it. the pip is not listed in the menu.
    but i tried the same thing where i purchased my pip, and it isn't listed there either.
    just prius 5, 4, 3, or 2.
    #9 bisco, Feb 27, 2018
