1. TwoPriusInTenn
    254
    66
    Tennessee
    2010 - 278,000 miles.
    Rough idle at start up then evens out. Replaced spark plugs with oem.
    Here is what TechStream says...
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Egr circuit needs to be cleaned
    RMB, TwoPriusInTenn and mjoo like this.
  3. TwoPriusInTenn
    254
    66
    Tennessee
    Thank you. Cleaned the EGR and the cooler today. Running better!!
    Mendel Leisk, RMB and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You get the intake manifold too:whistle:?
    Glad it worked out so far(y).
  5. TwoPriusInTenn
    254
    66
    Tennessee
    Thank you. Intake manifold, throttle body and egr pipe cleaned as well. Yeah, I've been busy!!!!
    Robert Holt, RMB and Raytheeagle like this.
  6. TwoPriusInTenn
    254
    66
    Tennessee
    PO302 2010.jpg PO304 2010.jpg Saga continues PO300, P0302, PO304 - I have cleaned egr, egr cooler, pipe, and intake manifold. Changed all four plugs and coils. Still throwing these three code. I'm thinking it's an injector issue. Here is what TechStream says
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Engine coolant level is stable?
    Grit likes this.
  8. TwoPriusInTenn
    254
    66
    Tennessee
    I have been having to add some as needed lately.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Sounds like the head gasket is compromised if the coolant is not on the ground ;).
    You could pull the spark plugs and endoscope them. I bet you’ll find one of them looks wet:cool:.
    Good luck and keep us posted (y).
    Grit and Pseudonymm like this.
  10. Pseudonymm
    Pseudonymm New Member
    28
    The great northeast
    What do the Techstream headers -3,-2,-1,0,1 mean? Some sort of chronology, I guess?
    I love the endoscope idea.
    Has there ever even been a documented case where fuel injectors -have- been the issue?
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Fuel injector being the reason why coolant loss? o_O
    Raytheeagle likes this.
  12. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    That's a good run for this engine.
    Check out Danlatu's thread. He reused the engine with close to 300k miles
    #12 mjoo, Aug 20, 2019
  13. Pseudonymm
    28
    The great northeast
    Fuel injector being the reason for misfires/engine trouble. It seems like they're often replaced/messed with as a last resort in a chain of simpler, less expensive repairs for engine trouble, when you ought to just be checking the cylinders for coolant.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’d swap coils before injectors ;).
    Since they are on top of the spark plug, the heavy lifting is done for access :).
    That’s what usually is swapped around and the injectors are usually left in place (y).
  15. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I was trying to decipher what the -3, -2, -1, 0, on tech stream as shown on your scan?
  16. TwoPriusInTenn
    254
    66
    Tennessee
    The spark plugs were the first thing I replaced and then all four coils. The injectors are on order and the next to replace. If the injectors don't do the trick, I'll be looking to replace the head gasket.
  17. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I suggest doing more diag instead of unleashing the parts cannon.
    RMB, Raytheeagle and TwoPriusInTenn like this.
  18. 2011Prii
    2011Prii Junior Member
    16
    38
    Indianapolis
    I don't know for sure, but I was wondering if that was the freeze frame data and time before (-3, -2, -1 second), during (0 sec), and after (1 sec) the code is triggered. I could be completely off though.
  19. TwoPriusInTenn
    254
    66
    Tennessee
    Took off the intake manifold this evening. The carbon residue in cylinder 2 was wet when I put my finger in.
    Symptom of a blown head gasket? Haven't taken out the plugs yet.
  20. The Critic
    3,193
    2,333
    CA
    Not necessarily.
