Featured Poised for Performance: 2023 Toyota Prius Prime Revealed | 50% increased EV range, 220 HP
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Nov 16, 2022.
  1. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    If you ever make the mistake of leaving a map light on, and run down your (non-Prime) 12v batt, as I did, you might understand me. :)
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,346
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Why? I've been there. I had to unexpectedly leave my Prius parked for 6 months. When I finally got back to it, the 12V was dead as a doornail. I used the key in my fob to unlock the driver's door, popped the hood, and stuck a cordless booster on the jump points under the hood inside the main relay panel. That powered the electronics and the car started right up when I pressed the button. Drove the car around for a half hour or so to run errands and things were fine.
    Now, I did have to replace the 12V battery later because its age(12 years) plus the complete depletion for so long finished it off, but I was able to get by without accessing the battery until it was time to swap it.
    ukulelegeek likes this.
  3. Tideland Prius
    16,559
    Yes
  4. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Also, while the price difference between a conventional battery and an AGM battery goes in favor of conventional... I only got about 6 years from the car's manufacturing date out of my Gen 4's conventional battery, and it's not the cheapest size out there. Granted, sample size of one, but.
    Looking at current prices, basically looks like any more than 7.5 years out of the AGM, and it'd be cheaper.
  5. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I know, I did exactly the same thing when the car was (sort of) new, thinking that lights all auto shut themselves off. Nope, not the map light. Later, the 12V battery was dead, and of course, the rear hatch wouldn't open. But I was able to hook up a battery charger to the special post under the hood and in no time, the car started right up.
    Having had many cars with the 12V battery under the hood, changing them when they are old, terminals all gunked up, battery dirty, I find having it in the rear so much nicer! The terminals stay clean, the battery stays clean, it lasts longer, and it is so easy to access without having to go through the firewall.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Easy to access? In my 2004 it took me an hour and a half to get access to swap the rear battery, and it was a royal pain. Further, it was risky. If you dropped a screw (which I didn't) it would fall all the way down inside the fender.
  7. bisco
    51,950
    for diy, the rear battery is fine. for people who need tohave someone else change the battery, a $100. special including labor is way better.
    what percent of prius owners are running inverters off the battery?
  8. ukulelegeek
    ukulelegeek Active Member
    159
    112
    Agreed, except I don't want an SUV. I don't like them. The only thing I like close to an SUV is our V. Same room, lots safer, cheaper to drive.
    Ugh, you just reminded me of the song "Dead Skunk in the Middle of the Road." by Louden Wainwright III.
    I'm running an inverter off the 12V battery, only in emergencies.
    #88 ukulelegeek, Nov 21, 2022
  9. bisco
    51,950
    that's one :)
  10. Gokhan
    Gokhan Senior Member
    6,217
    2,465
    Paramount CA
    A very nice video of the incredible new Prius Prime.
    Richard2005 and Tideland Prius like this.
  11. Lee Jay
    5,850
    4,036
    I've run three different inverters of my Prime - a 150W off the 12V socket, a 300W true-sine off the battery under the hood, and a 2000W modified-sine off the battery under the hood.
  12. bisco
    51,950
    still one
  13. Gokhan
    6,217
    2,465
    Paramount CA
    Another nice video.
  14. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    I do not know, the last time I actually cleaned my rear glass on the prime was probably two years ago before I added the vortex generators. Even in the heavy rain, it just all blows down to the bottom and off the trunk lid and the glass stays clean at any speed above 50mph.
  15. Lee Jay
    5,850
    4,036
    And in heavy, wet snow?
    For me, it sticks on the rear window at any speed.
  16. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    No snow here in california. But in general I just don't get any rain on the back after about 50mph.
  17. Lee Jay
    5,850
    4,036
    Rain isn't a problem. It's snow. If the weather is cold and thus the snow is light and fluffy, it's not problem, it just blows off. If it's warm, around freezing temperature, the snow is wet, heavy and sticky, and I've had it stick to both the rear window and the outside rear-view mirrors despite the defroster being on and the mirrors being heated. This means you can't see behind you *at all*.
  18. AndOne
    AndOne Junior Member
    Boston
    I'm currently driving a 2017 Prius Prime with about 87,000 miles on it. I'm interested in test driving this when it comes out but wouldn't think of buying it until at least the 2024 model. I'm on my second Prius now and my biggest concern has always been road noise. I'm hoping they addressed this. Any improvement would help.
  19. bisco
    51,950
    different tires can help
  20. Gokhan
    6,217
    2,465
    Paramount CA
    If you think Prius Prime has road noise, you have never been in a Honda. Consumer Reports rated Prius Prime 4/5 in road noise. They rated Honda Civic 2/5.
