Featured Poised for Performance: 2023 Toyota Prius Prime Revealed | 50% increased EV range, 220 HP
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Nov 16, 2022.
  1. Trollbait
    12,543
    What about the Corolla?
  2. Gokhan
    Gokhan Senior Member
    6,248
    2,479
    Paramount CA
    3/5—better than Civic, worse than Prius Prime.
  3. Tideland Prius
    16,559
    Really? I thought the Corolla was quieter than the Prius. The Prime was noticeably quieter than my Gen 3.
    Gokhan likes this.
  4. Gokhan
    6,248
    2,479
    Paramount CA
    Yes, these are the CR ratings.
    Tideland Prius likes this.
  5. ukulelegeek
    ukulelegeek Active Member
    159
    112
    There's a Toyota service guy on youtube, with a video about 'why is my car so loud?' It might give you some insight.
    AndOne likes this.
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    All-new Toyota Prius Plug-in hybrid
    Officially Premiered in Europe now. No real new information except Toyota Europe estimated EV range of 69 km (43 miles). This is NOT WLTP. Also estimating 8 km (5 miles) of EV range per day with the solar roof.
    Same info we already have:
    164 kW (220 hp) system power
    112 kW (150 hp) 2.0L engine
    120 kW (161 hp) MG2
    I was hoping to find out info on the gas tank size but got a bunch more pictures in colors we won’t be getting.
    Edited to convert the sun roof production.
    iPad ? Pro
  7. Trollbait
    12,543
    Well, it very likely is, as I don't see Toyota running NEDC tests that can't be used, nor using Japan results for Europe. They just aren't officially sanctioned yet. From past releases, this number is likely lower than what the official one will be.
  8. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    I would add that the model presented in Europe today is the PHEV and does not have the red accents on the seats nor on the dashboard.
  9. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah you are correct I should have stuck "official" before WLTP because not everyone understands what pending final homologation means. Bestcarweb started putting in estimates as well but they were estimating JC08 and being a little optimistic even for WLTC conversion. 56 miles (90 km), maybe @bisco could do that.;) Although the battery is 25% smaller than the RAV4 Prime, it is lighter than the old Prius Prime which is 925 lbs (420 kg) lighter than the RAV4 Prime, more aerodynamic and arguably newer more efficient power electronics, I'm hoping it beats the RAV4 Prime 42 mile AER.
    スポーツカー以上ってマジか! 風穴を開けろ!! 新型プリウス0-100kmh6.7秒、233馬力の衝撃 - 自動車情報誌「ベストカー」
    Partial translation:
    " The capacity of the drive lithium-ion battery has also increased by 55% from 8.8 kWh to 13.6 kWh, and the EV cruising range is said to have improved by more than 50% from the current 68.2 km (JC08 mode), so a simple calculation is 102 km or more. It will be. When converted to WLTC mode (assuming a 12% reduction in JC08 mode), it is 90km or more, and most of the daily driving can be covered by EV driving.
    A plug-in hybrid system for the new Prius based on the THS II system. A plug-in hybrid derived from a hybrid with an increased lithium-ion battery and an external charging device"
    JoeBlack and Tideland Prius like this.
  10. bisco
    51,996
    I hope to try someday :)
    drash likes this.
  11. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    I noticed that the slow pan shots of the official Toyota USA walk around shows just a J1772 connector and no DC fast charge at around 0:09 and later when going over the interior a 120v/1500w plug at 3:48.
    drash likes this.
  12. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
  13. Trollbait
    12,543
    Would have been surprising for the US to get fast DC charging.
  14. pjdemmitt
    pjdemmitt Junior Member
    25
    Columbia, MD
    Good question. My wife's 2017 doesn't have one. She had two flat tires, not at the same time. But the tires couldn't be repaired. Fortunately (or not), the car was in our driveway so AAA came and towed her to get it fixed both times, but it was an inconvenience not being able to just replace the tire with a donut until it was convenient. I vowed I would never buy a car without a spare. So this is an important question
    hill and Mendel Leisk like this.
  15. Mendel Leisk
    41,515
    Same here: no spare, no sale.
    hill likes this.
  16. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I agree. I think having no spare is stupid (flat tires happen), and donuts are dangerous. I want a full size tire.
    My car before the Prius was a van. It had a donut, and I told the salesman that for me to buy the car, they needed to put a full size tire in there. At first, he told me a regular tire wouldn't fit. I suggested that the car is made for other countries as well, and that a regular spare ought to fit. It did, of course.
    Does any other country have donuts? I think the move away from real spare tires, and now the elimination of donuts (now they give you a can of spray goo), is to reduce weight "for better mpg" they tell us (I can't imagine it makes much difference), and to reduce the cost of the car for manufactures.
    Is driving with a tire filled with spray goo a safer alternative than driving on a donut? Maybe, because it might be that having no spare is better than a donut? I bet we've all seen foolish drivers on the highway going 70mph with a donut instead of a tire. I can only imagine the loss of control in a curve or braking in an emergency. Is there any data on accidents caused by driving on a donut?
  17. Mendel Leisk
    41,515
    I’m ok with a compact spare, aka temporary spare. That second expression sums it up: use it to get yourself to your destination (if possible), and if needed, to a tire repair place.
    Prashanta likes this.
  18. Trollbait
    12,543
    Wasn't a spare tire option mentioned elsewhere? Perhaps for one of the other markets.
  19. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    There was a press photo I can't remember where I saw it but they showed a spare under the trunk. It could have been the Euro or Japanese version.
  20. bisco
    51,996
    i've been living with a spare in the hatch for ten years, they've got me brainwashed.
    at least the new prime has the flat deck. in the gen 4, the spare would have taken up the whole hatch
    Trollbait likes this.
