Poll: Are any of these really problems?
Discussion in 'Gen 3 Prius Main Forum' started by ggood, Oct 1, 2009.
  1. Red arrow in energy monitor hard to see in daylight
    41 vote(s)
    25.5%
  2. Car computer overestimates MPG
    81 vote(s)
    50.3%
  3. Air Conditioning display is cloudy/blurry
    36 vote(s)
    22.4%
  4. Delay in answering calls with Nav and Bluetooth
    28 vote(s)
    17.4%
  5. Satellite radio signal is weak
    31 vote(s)
    19.3%
  6. Satellite radio display is truncated to 16 characters
    38 vote(s)
    23.6%
  7. Ghost image on speed display
    16 vote(s)
    9.9%
  8. Slip indicator comes on when at a full stop
    15 vote(s)
    9.3%
  9. Can't hear nav voice over stereo
    10 vote(s)
    6.2%
  10. Phone numbers disappear from contact list
    15 vote(s)
    9.3%
  11. Apparent screen burn-in
    24 vote(s)
    14.9%
  12. Navigation DVD not detected at car boot up
    16 vote(s)
    9.9%
  13. Cargo net panel separation
    44 vote(s)
    27.3%
  14. Auto-dimming mirror sensor wrongly positioned
    30 vote(s)
    18.6%
  15. Brakes grabbing in reverse
    48 vote(s)
    29.8%
  16. Momentary loss of braking power when navigating over a bumpy surface of pot hole
    56 vote(s)
    34.8%
  17. Cruise Control requires too much brake pressure to cancel
    39 vote(s)
    24.2%
  18. None of the above are considered problems
    8 vote(s)
    5.0%
Multiple votes are allowed.
  1. 3PriusMike
    3,101
    2,421
    Silicon Valley
    It is interesting that, as I post this, the item that most people voted for is the mpg overestimation. IMO, this is (collectively) wrong. IT is, essnetially, telling Toyota that the most wrong or annoying thing about the car is that it overestimates the mpg by ~5%.
    This is silly, because it really affects nothing. The car works fine with or without this adjustment. I'm as big of a proponent of trying to get your best mpg as most anyone here. (Yes! my last tank was over 60 mpg...60.3 mpg vs 63.3 estimated). But this makes no difference to me. It is just a fact as to how good or bad the estimation is and I really wouldn't pay extra to have it more precise.
    However there are a number of things about the car that I would like to be designed different/better that are more important (to me). I've had none of the other problems listed, personally. But I did vote for the cargo net since it appears to me that others have had this issue.
    All this said, since it is my 3rd Prius (one of each) for my family, I'm pretty happy with each generations incremental improvements.
    I've gotten about 5 surveys via email from Toyota and (apparenetly) others that got my email info from Toyota. (This is more than for the 2004 but less than for the 2001). I don't think that the surveys have enough focus to be able to identify small little annoyances...so maybe this type of poll is good, but not scientific or statistically valid.
    3PriusMike
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    The error on my fuel mileage is 1.5% optimistic and I consider that pretty darn close so don't consider it a problem in my case.
    Out of all the others in this list the only one I've noticed (either due to lack of options, or lack of attention to detail) is the ghost image of the speedo. But it's so minor I don't consider it an issue.
  3. Grateful11
    Grateful11 Member
    107
    Central, NC
    Of those items on the list the amount of pressure/pedal movement is the only one that really bothers me. I've owned 17 new vehicles in the 25 years and this car by far takes more pedal pressure to turn off the cruise. It feels like the brakes are actually engaging before it's turned off, not a good idea.
  4. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I am not sure how the computer estimates fuel efficiency, but mine reads about 1.2 mpg on the "generous" side. Actually, I consider that remarkable.
    My Dodge truck reads about 4 mpg too "generous." I read that it is calculated on the weight of the fuel in the tank .... not sure I believe that.
    I wonder how the Prius does the estimate?
    I do not cnsider any of the other issues significant, except the brake grab when backing. I had hoped it would get better with age.
  5. bwilson4web
    16,554
    It looks two are missing:
    • floor mat
    • 'check engine light' when fuel is exhausted
    But I went with the indicated MPG since it leads to doubts about our actual vehicle mileage.
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Hey Bob - If it wasn't listed in the summary of 2010 problems thread when I created the poll, it didn't get listed. I'm not sure what the floor mat issue would be for the 2010, but you should probably post to that sticky thread if you think those 2 items are problems. If that list grows, a 2nd poll can always be created. My real intent was to question some of the items on the list, but instead, anything listed is getting reinforced to the extent it gets any votes at all!
  7. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Like many, while I checked several of these because I consider them to be actual issues that could be improved (such as blurry AC screen and Bluetooth delay), most of them are minor. I did not check the overestimation of mpg because even though it seems to overestimate my mpg by 3% or 4%, it's been very consistent. The variances between my calculated results and the MFD on my Gen II were all over the place. The brakes grabbing in reverse is really the only one I might consider a real problem, but I've only experienced it once, and it was in my driveway and didn't bother me too much. The slip indicator coming on when pressing down on the brake is definitely not a problem, as it is the Hill Start Assist feature, but I agree with the poster that said the icon is confusing and makes a feature look like a problem.
  8. accordingly
    accordingly Member
    268
    63
    Madison, WI
    This issue is not the hill assist coming on.
  9. PriusRos
    1,973
    218
    Rockville, MD
    Isn't that the traction control (or whatever it's called)? It will engage if you brake suddenly or hard.
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    You may be thinking of the ABS (Anti-lock Breaking System). The Traction Control keeps the drive wheels from slipping by using the brake on the spinning wheel and limiting power delivered to the wheels.
    The slip indicator lights for the Traction Control without beeps and the VSC with beeps. It is also used for the Hill Start Assist but only when the car is stopped, if the car were in motion it would indicate one (or both) of the other two systems activated.
  11. accordingly
    accordingly Member
    268
    63
    Madison, WI
    The issue people describe is when the slip indicator comes on solid when the car is stopped.
    The Hill Start Assist will flash the indicator light.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    *** Added None of the Above choice ***
  13. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    " Some are simply not real problems, like losing braking when going over bumps. As explained in the threads, the ABS is working as designed. I don't understand why people expect anything different. "
    This is the ONLY REAL problem listed here. It's something that can wreak your car. It is NOT something that I have ever felt in any ABS car! :(
    MY Volvo, BMW and Mercedes didn't behave that way and a Prius should not.
  14. bwilson4web
    16,554
    Interesting that the poll does not include the floor mats.
  15. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    You did ggood, reall ggood. Oops, I mean well. You done real well, ggood.
    Is this because of the recall, Bob? The 2010 wasn't part of the recall, so I don't think it applies. If there is another issue with the floor mats, I'm not aware of it.
    I looked at this poll as questioning whether any of these things operated or failed to operate (or had such poor operation they caused extreme frustration). For this reason, I did not include the momentary drop in braking assist on bumpy streets, because I was accustomed to it and have driven to manage it.
    I included the things that have affected me, such as the cargo net and the delay in answering calls via the handsfree system. And even though it doesn't really malfunction, I included the overstatement of FE, because I think it can give the reputation of the Prius a real hit.
    I won't say some of the others are not or may not be aggravations, but they haven't applied to me!
  16. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Maybe I should have prefaced that with an IMHO! I guess that's why we have the original thread and this poll....
    See my posts #1 and #26 above. Maybe the intent wasn't clear enough from my title.
  17. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I thought the cargo net and foggy airconditioning screen were fixed by service bulletins or whatever Toyota calls them? I also think there needs to be some distinction made of what or how one defines a 'problem'? If the poll is limited to only those items in the list then why was the one concerning 'rattles' from the front right side of the interior left out? That is one 'problem' I'm having that I thought disappeared but has now returned.
    As far as the thread in general goes why hasn't anyone who has accidentally engaged the cruise control with 'Resume' using their knee and experienced a momentary unscheduled acceleration until they brake listed that as a 'problem'?
  18. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Maybe we need more polls? Or before posting a poll go into a sort of dummy beta test to see how people react which is pretty tough for a poll creator to predict?
