Poll: Are Prius brakes a problem?
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Jan 1, 2010.
Experience with Prius braking
Poll closed Jan 15, 2010.
  1. 2010 Prius - have one and no brake issue (one answer)
    33.3%
  2. 2010 Prius - about once per month (first answer)
    13.5%
  3. 2010 Prius - about once per week
    7.0%
  4. 2010 Prius - about once per day or trip
    2.9%
  5. 2010 Prius - scary, safety issue (second answer)
    10.5%
  6. 2010 Prius - can live with it
    14.0%
  7. 2010 Prius - no big deal, not a risk
    17.0%
  8. 2004-09 Prius - have one and no brake issue (one answer)
    14.0%
  9. 2004-09 Prius - about once per month (first answer)
    5.3%
  10. 2004-09 Prius - about once per week
    1.2%
  11. 2004-09 Prius - about once per day or trip
    1.8%
  12. 2004-09 Prius - scary, safety issue (second answer)
    0 vote(s)
    0.0%
  13. 2004-09 Prius - can live with it
    3.5%
  14. 2004-09 Prius - no big deal, not a risk
    14.0%
Multiple votes are allowed.
  1. bwilson4web
    16,531
    A few new data points:
    There were a few reports that I was not able to find via Google 'street view.' I'll take 10-15 minutes but I can't post what I can't find.
  2. bwilson4web
    16,531
    This remains an interesting question. When we test drove a 2001 Prius with less than 100 miles on the clock in 2001, I could detect the regen transition just under 5 mph at stops. But by 2005 when I picked up our 2003 Prius, I couldn't detect it in a car with 49,000 miles.
    I've never felt the regen transition with out 2010 (ZVW30) Prius. As for the braking anomaly, I've found one pot hole that has a momentary, very fleeting, effect that I can detect but not quantify. In fact, if it weren't for the braking threads, I wouldn't have even noticed it. I continue to try and replicate the symptoms.
    Without some way for everyone to be able to replicate the problem, it remains an 'intermittent' problem. These are maddening to address because the engineering team (even NHTSA) can't apply normal engineering practices to diagnose it. "Shouting" is not a symptom ... it takes rubber on road.
    So far, all of the reports are beyond my day-trip comfort zone. So far, I've not been able to find a road rough enough with the right pattern to replicate anything but a momentary, fleeting impression. I'm not doubting the reports of others but reporting I can't replicate it, yet.
  3. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    Bob,
    I agree with everything you said above (except the part about a G2 Prius not having a lapse of regenerative breaking under 5 MPH - my wife and I both have felt this on occaision in our 2005 when we had it) as I've only had one experience in our new 2010 that I think is even close to what others are saying and for me it was a non-event. I'm going to keep trying to get the car to do this when I drive it (usually on weekends).
    Mike
  4. enigmaticfox
    enigmaticfox New Member
    Massachusetts
    I'm coming in a little late to the discussion, but I don't think this is always the case. I practice extremely conservative driving, slowly coasting to long stops, and I have also experienced this sudden loss of braking while going over a bump. In my case, I was coming down a neighborhood steep hill (slowly) and doing my usual long slow braking for the intersection at the bottom. About 10 ft from the bottom of the hill and the intersection, there was a sudden sharp bump from a pothole, and abruptly my brakes weren't braking any more.
    I was able to regain braking control by releasing the brake entirely and then slamming back down on the brakes again, but it was quite startling, and I'm just glad that I figured it out in time to miss sliding out into the intersection! :eek:
    Take care,
    --Sherri, otherwise happy 2010 Prius owner :)
  5. bwilson4web
    16,531
    Hi Sherri,
    Nice first post:
    By now I hope you've seen Toyota is planning to distribute a fix. My suggestion is to document where you've seen the problem; test that it is still there before getting the fix; and testing it after the fix is in. I've been collecting Google and Google Street View and photos of places where this happens:
    We've got over 20 and counting locations and images. If you want to add one or more that would be good with me.
    Thanks,
  6. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    Its happen to me 3 times only over the 5 months that I owned the car. 1 of them was quite scary on the highway.
    To reproduce the problem, you have to travel at a constant speed not too slow and the brake have to be applied slightly and continuely (Slowly slowing down). There must be another car closely in front of you in order get the out of control feel. When you go over the potholes your car will lost the brake for a split second and you will feel like you dat forward and going to hit the car in front.
  7. hybriddriveguy
    98
    63
    Sanford NC
    I will say after working in the auto repair industry for over 30 years that new technology is always un-nerving for consumers and technicians.
    When ABS brakes were first introduced in the US, we had a constant stream of customers, who did not trust their dealer when they were told the brake pedal was supposed to push back at them and they shouldn't be able to lock up the brakes. We spent many hours of our time re-educating our customer to trust the technology. Since the late 70s, ABS feel has changed very little from one make to the next, even though the methods have varried greatly.
    When I first began studying the Gen3 Prius, I was immediately impressed that someone was finally trying to do away with all the noise and pedal pulsing associated with an ABS system, but I also thought, "here we go again" on re-educating our customers. We have talked to many since the news media and our government has taken aim at Toyota and not one has failed to stop their car as expected.
    I think the sensation of feeling like the car is not doing anything creates an immediate sense of panic, but is probably not causing the vehicle to stop any slower than it could normally.
    With the old system, the solenoids would immediately give you feedback in the pedal that something was happening before the brake pads were engaged, but we have lost that feedback with the new design.
    I think this is a good thing, but it will certainly take some getting used to.
    I am also concerned greatly with the level of attacks being leveled at Toyota given the scale of their failures and their quick response. Are we trying to "level the playing field" a little?
    GM had a big problem with brakes on their front wheel drive cars starting in 1980 that would cause the rear to lock up and send the car into a skid. This continued to be a problem for at least 10 years, even though there had been many accidents and deaths associated with the failures. During that time, the media and the government were pretty quiet about it.
    I guess we lived in a different world then, but it is food for thought.
    This is just my opinion and I am not trying to dismiss or disrespect anyone over this issue.
  8. scottle
    scottle New Member
    Sheffield, UK
    Has anyone tried replicating this scenario but not changing the pedal position when it happens. Both times that it's happened to me instaict takes over and I hit the pedal hard. It would be interesting to see what happens if the driver didn't do this, would the brakes still reapply???
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Thanks, hybriddriveguy. I think your post provides a lot of needed perspective. Our world has become more polarized, and less tolerant to anything not perfect. Many of us now think that we live in a theme park where everything is clean, safe, and beautiful. My wife and I see this all of the time with sailing and rock climbing. There are a lot of people who think that the government should control the weather and make sure that rocks don't fall. Life just isn't that clean or easy. Hopefully we all do our best, and try to do the right thing, but at the end of the day a lot of s__t happens.
    There are some bad apples; people and companies that try to cheat. They deserve to get smacked. However, for the rest, we need a little more tolerance and a whole lot less hysteria.
    Tom
    3 people like this.
  10. enigmaticfox
    Massachusetts
    Hi Bob,
    Yep, I realized after posting and then reading the entire thread that I'd jumped the gun a bit (as well as bringing back a mostly dead thread...sorry about that, all). What a first impression to make! Thanks for being understanding despite my newbieness. :redface:
    I will have to see if the pothole/bump is still there; this happened months ago, and I really just chalked it up at the time to "interesting albeit spooky Prius quirk" and have just been watchful since then. It was only yesterday when I started reading about the investigation that I said "Oh wow, that sounds exactly like what happened to me!" and decided to go to PriusChat to see if others had seen it too. I didn't realize that it was such a polarizing topic!
    Trust me, I'm not a Toyota or a Prius hater. I love my 2010! Makes our summer drive to North Carolina from snowy New England more fun again. I do wish that this investigation didn't hit at the same time as their other massive recalls, Toyota is going through a very hard time right now.
    Take care,
    --Sherri :focus:
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    When we first got our Prius, we were driving across the Astoria bridge, in the pouring rain, I was driving, and we were on the OEM tires.
    I was going pretty fast, noticed I was getting really close to the T intersection (the stoplight was red)... I slammed on the brakes as I hit the painted white bars on the road. I experienced a combination of hydroplaning, slipping, and the anti-slip feature, all at the same time. It was freaky. I very quickly realized that the fault was MY OWN, for driving too fast for the conditions, and for hitting the brakes hard on those painted stripes.
    After replacing those OEM POS tires, I've never had that sort of problem. I do, occasionally, notice the slip/anti-slip response when I'm starting/stopping on a railroad track or a painted white stripe, when either is wet. It's momentary, and doesn't bother me much anymore.
  12. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  13. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Yes, I have tried this when the lane was clear well ahead of me. The brakes did re-engage very quickly, well under a one second delay. Once re-engaged, they were not at the same stopping power as they were initially.
  14. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    over at NASIOC.com and Legacygt.com the Bridgestone OEM re92's are known as "SUCKstones"
    nobody really likes them for spirited driving.
    for all around driving they are just adequate.
    the "bean counters" are everywhere.
  15. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    another spot to repro
    I know Bwilson4web is collecting data points but I'm not sure where the best place to post them is now...
    Here's another report of a place to trigger the braking anomaly on a 3rd gen from a former coworker. He asked me to post it for him. I have not verified whether I can repro it there on my 2nd gen, yet. (It's 13 miles from my apartment and it's not an area I normally go to at all.)
    296th Ave NE and Carnation-Duvall Road, Carnation, WA - Google Maps
    In his own words:
    I clarified with him that he's coming down 296th Ave NE towards the highway.
    From some of his posts at work, long ago, he said that the braking anamoly is repro on his former 1st gen but feels consideradbly worse on his 3rd gen. From his old post (and how he described the coming around a corner on a gravel road, washboard, downhill, etc.) it sounds like he's talking about the exact same road as above. I can clarify. He also later stated that he's owned many other ABS equipped Toyotas and that his non-Priuses don't exhibit this kind of feedback while braking down that road.
  16. bwilson4web
    16,531
    Thanks,
    The "washboard" is another triggering condition but it appears to be a frequency triggered event. I'm about to share a hypothesis ... NOT A FACT!
    I noticed in the event I captured that the variation in braking force while going over the speed bump was very similar to cycles seen in ABS braking. I suspect the 800 ms. braking pause was an attempt to avoid a potentially, destructive coupling between the vehicle harmonics and the ABS system. One approach is to disable the active, ABS braking force modulation but unfortunately, at zero Newtons.
    If this is the case, the right answer is to disable the active ABS modulation and go with a constant brake force, hopefully, at least the same as the ABS average. .... But THIS IS SPECULATION!
    I look forward to regression testing the bump.
  17. amirzo
    amirzo Junior Member
    Israel
    I had a 2007 gen ii for almost 3 years.
    did not once have any issue with the brakes.
    for 5 months now i have a 2010 gen iii,
    experienced the loss of brakeing power once (about 2 months ago).
    i was surprized and startled. Thankfully there was no one infront of me.
    Did try to recreate the situation numerous times on the very same spot, with no avail.
  18. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Bob, I have one for you... A Gen II report!!
    los feliz,ca - Google Maps
    Traveling away from camera, rough spot in lower portin of pic, however with recent rains it has degraded further than it looks!
    I have a Gen II 08, V and run 42-40 PSI front/rear so I feel a lot of the drive. After 17,000 mies I can tell blindfolded when I am in Regen, Warp Stealth, and Battery or ICE acceleration.
    It was medium traffic, coming up to to a stop way ahead, plenty of cars in front of me. I was going 35-40 tops, and since I knew I was going to have to stop ahead, I backed off the gas and went into Warp Stealth for a bit, NO arrows at all,then Regen mode, I traveled like that a bit, then hit brakes lightly. I could feel the deceleration effect, then I hit the rough patch in the pic. I felt the car drop into what felt like Warp Stealth mode, niether acceleration, nor deceleration. The effects lasted pretty much like your accelerometer readings, a split second, right after the bump, the "Problem" occured, a half sec of "Coasting", then deceleration again.
    I actually started laughing...
    This is what all the fuss is about....
    C'mon!!
    I promptly went around the block, and repoduced the effect.
    Feeling quite pleased with myself for not only noticing the "Effect" but actually reproducing it, I Goggle Mapped the spot for you, and here we are!!!
    I will stop by the dealer tomorrow, and talk to my Service Rep, have him put my name on a list of trouble makers. AND MOVE ON!!
    Hey, NICE JOB, and ATTABOY, for the accelerometer write up. Well pesented, and honestly as I was laughing, in my head I was flashing back to your graph...Pretty much spot on for the effect I felt!
    I downloaded an App for my Droid that will do XYZ readings. I think I will go back and see if I can record the "Effect"
    It may not be as sensitive as your unit however!! If it records, I will do a Save Screen and post the pic!!
    Thanks for your posts, always a great read!!!
  19. bwilson4web
    16,531
    I have to admit some chagrin about the brake pause. Huntsville streets are so slippery when wet that there might have been dozens of these events but neither I nor my wife would have noticed them. Still, I welcome any and all who are able to replicate and quantify the effect.
  20. J4mes
    J4mes New Member
    Los Angeles
    I've only had situations where the traction control will fly in right when I'm about to break, can be a bit scary.
