POLL: Did the ECU Update Recall work for you?
Discussion in 'Gen 3 Prius Main Forum' started by thbjr, Feb 11, 2010.
  1. I have experienced and was able to duplicate the brake issue before the ECU update, but no longer ca
    15.0%
  2. I have experienced and was able to duplicate the brake issue before the ECU update, and still can.
    5.6%
  3. I have experienced the brake issue before the ECU update (but couldn't intentionally duplicate), but
    10.6%
  4. I have experienced the brake issue (but couldn't intentionally duplicate) both before and after the
    3.8%
  5. I have had the ECU update done, but need more time to assess if it’s fixed the issue.
    19.4%
  6. I did not experience the braking issue before or after the update.
    26.9%
  7. I did not experience the braking issue and will not be updating anytime soon.
    18.8%
  1. volvoswede
    volvoswede Junior Member
    26
    idaho
    a
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes, I received a recall notice yesterday in addition to the new OCI letter and maintenance manual.
  3. gazz
    gazz Member
    216
    Coventry, UK
    IrishPrius
    Does the feel seem better or do you prefer the softer feel, also does the regen seem the same?
    Thanks
  4. john burns
    john burns New Member
    37
    Jacksonville Florida
    Have not ever experienced the problem and have never heard from Toyota or my dealer about it
    As for customer service I think they get a failing grade. They call me and ask if I was satisfied with my oil change but when the media keeps telling everyone how unsafe these cars are,.....where's Toyota or the dealer?
    Love the car, but think the company and dealer get a failing grade
  5. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    I got a phone call from my dealer, Modern Toyota of Boone, last week telling me to come in for the brake fix. I went in today to set up the appointment and the service writer said they hadn't done any yet and I would have to wait for my recall letter before they could do it. :confused:
    I've experienced the problem a few times since I bought the car last June and, although it certainly grabs your attention when it happens, I don't see it as that big a deal.
  6. thbjr
    thbjr Member
    326
    63
    Phoenix
    Got my recall letter for our Blue Prius yesterday, 3/8,.... we had the update done to that car on 2/12. Our White has yet to be done, but no recall letter for it. Go figure :confused:
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Have not received the letter on the brake recall. Had the upgrade done last week. They had the car 55 minutes and did the brake update, drained the excess oil from the crankcase as they overfilled it on the first change, and had them check the transaxle coolant drain plug based on the TSB. I also had them order the new Climate Control screen as mine is blurry. I watched them do the work and asked for a printout showing the before and after and they had no problem giving that to me.
    I had the brake problem before and could reproduce it every time on a rouch patch of pavement near my home. I can still reproduce the problem, but it is much better in that the braking pause is much shorter now. Before the update, if anyone had experienced it on this specific pavement patch, even if they had no prior knowledge of the problem or regen brakes, it would have grabbed their attention in a nasty way. Now, I believe only the most observant and aware driver might notice it. I can still feel it because I know what to look for. The brake pedal feels a little bit different, in that it seems to be smoother through its range, but I don't find it to be a major change.
    2 people like this.
  8. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    It recurred twice yesterday, and to the same degree and under the same circumstances as before. Is there anyway to find out if the dealer actually made the update?
  9. bwilson4web
    16,531
    Drive to another dealer?
  10. tumbleweed
    4,067
    692
    Eastern Oregon
    I don't know if their Techstream system will show the version number of the software or not but it sure would be easy for them to do it again just to be sure. If it were me I wouldn't hesitate to take it back and ask that it be redone.
  11. DetPrius
    545
    92
    Southeast Michigan
    As the dealer to provide a printout showing the before and after versions numbers so you can see what has changed.
  12. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    My version was 103 at the start and 106 when finished. It showed it right on the computer screen as i watched the tech do the update.
  13. bruce farrel
    bruce farrel New Member
    Ohio
    Is the ECU update working
    I had the ECU update to correct the braking problem done this weekend. But tonight I experienced the braking problem again. Is anyone else continuing to have this problem after the recall work was completed?
  14. sandsw
    sandsw Member
    99
    37
    Sydney Australia
    Re: Is the ECU update working
    Hi Bruce,
    Not me.
    When I experienced the problem (the day before the ECU was flashed), it seemed to me to mimic the feel I always had in my '94 Ford. Haven't experienced it since.
    Cheers
    Warwick
  15. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Yes, the problem still exists fo me.
  16. bwilson4web
    16,531
    There has been at least one credible report that the dealer may not have applied SSC-A0B. Don't rule out 'incompetence' in getting the fix applied.
    The other thing is the brake fix is specific to a well defined set of conditions. Can you describe:
    • Where it happens? (Assuming it is reproducible.)
    • What speed when it occurs?
    • Weather conditions?
    Thanks,
  17. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    We never experienced the alleged brake interuption, before or after the ECU re-flash.
  18. LaMesaGuy
    LaMesaGuy Member
    103
    La Mesa, CA
    I brought my 2010 Prius w/AT package in May of 2009. Never had any problems with braking at anytime in any weather on any type of roads. My 2010 Prius runs like a clock, it keeps on ticking.
  19. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I did not have any braking issues with my 2010 III prior to the brake recall. After the flash upgrade though, I could definitely feel the difference in the "feel" of the brake pedal in that it felt more like my past non-hybrid car brakes.
    "Assuming" that you are talking about the same brake issue, or transfer delay between regenerative and friction braking, then I would agree that you may have an issue with the dealership not
    applying the flash upgrade correctly.
  20. bruce farrel
    Ohio
    Bob,
    Before the upgrade I experienced the brake problem 4 times (after 1st 3 I did some research and found the 100 complaints at NHTSA). First time was going over a small icy patch, 2nd and 3rd on speed bumps in a parking lot on wet pavement. Speed was slow and braking was moderate (regen engaged I assume). 4th time was on snow covered road. I could make the condition occur at will. Car slowed nicely then brakes just released and car just cruised until more pressure was applied and friction brakes engaged).
    After the fix I was driving at about 20 mph on wet pavement, in the rain and slowing when I hit a bump and the brakes released again. It doesn't feel all that terrible but I am afraid it will happen one day at an intersection and I'll end up in cross traffic.
