Poll, do you use Google Maps to get max EV range?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priuskitty, Aug 5, 2012.
  1. yes
    42.9%
  2. no
    57.1%
Multiple votes are allowed.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I use Google Maps to plan my EV range trips. comes in handy.
    51,155
    phone or puter?
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    me? puter
    51,155
    are you getting elevation or just miles?
    Andyprius # 1 likes this.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. bisco
    51,155
    not a bad idea, i would love to see elevation change as well, can have a large effect on range. i think someone said it was available in a phone app.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    how do you calculate elevation/EV range?
  8. bisco
    51,155
    mentally, by experience. i suppose a computer program could do it if there was one. wouldn't that be sweet? plug your destination into the nav and it gives you a new ev range.(y)
  9. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Google earth has elevation change
  10. bisco
    51,155
    can you get directions, distances and elevations?
  11. The critical component in efficient driving is knowing if you are traveling up,down or flat, right now, I don't think any map program will tell you that.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    someone should suggest this to the Toyota navigation guys
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    tomorrow I will be testing the map out. I have 8.3 EV left.
  14. DLee
    DLee Junior Member
    81
    Future on board NAV could learn from routes that are repeated. This data could help choose the best route. And it could optimize EV battery usage over the course.
  15. bisco
    51,155
    the toyota nav guys have a lot of learnin' to do before they tackle something like this. they would have to work with google or someone.
  16. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I voted Yes only because I used Google Maps to find a shorter route to work that avoided the freeway once I got my PiP. But aside from that, I don't use Google Maps specifically for EV range maximization.
    Anyone ever tried the Eco Route or whatever on the nav? Shouldnt that do something similar (EV maximization)?
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  18. chesleyn
    596
    158
    Los Angeles
    So you guys have seen my stupendous EV range on my way home from work.. here is the route profile up.. so you can see why I get so much EV on my return trip. Up I'm getting about 80 mpg… return in 300's.
  19. bisco
    51,155
    wow! now that's a hill!
  20. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    When I set a destination in the car, when it presents me 3 routes, if I remember correctly, each one has a time, distance, as well as a $ cost.
