Poll on "Tire Repair Kit"
Discussion in 'Gen 4 Prius Main Forum' started by dorunron, Jan 24, 2016.
  1. Not purchase that model but opt for a 2 or a 3 model
    11 vote(s)
    20.0%
  2. Buy a spare on your own along with a jack and lug wrench
    5 vote(s)
    9.1%
  3. Ignore it all together and buy the model I want regardless if it comes with a spare or not
    22 vote(s)
    40.0%
  4. Purchase a alternative brand altogether leaving the Toyota brand behind you
    4 vote(s)
    7.3%
  5. Purchase a plug kit and carry it along with a electric air pump rather than use the tire repair kit
    10 vote(s)
    18.2%
  6. Buy the vehicle I want and take other actions as needed that are not reflected by this poll
    1 vote(s)
    1.8%
  7. Choose other options that are available that this poll does not list
    2 vote(s)
    3.6%
  1. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    It probably will - mostly.
    Unfortunately, this is one of those things where probably and mostly are not nearly good enough, at least for many of us.
  2. Mendel Leisk
    42,381
    I've had a couple of flats with this Prius. One was a finishing nail, that fit your "typical" scenario. The other was a more substantial bolt, that had the tire dead flat in a a mile or two.
  3. frodoz737
    frodoz737 Top Wrench
    4,812
    2,563
    33
    Let's be honest here folks. If you don't care whether you have a spare (or repair kit :LOL:), your weren't going to use them when needed anyway...and for the rest, doesn't everybody have chocks?
  4. Trollbait
    12,835
    I had large bolt in a tire once. It actually plugged the hole for several miles, and I might have gotten home with it in place if I stayed to slower roads.
    I've only used the goo in trying to seal a mystery leak, so I can't say how well it works for larger holes. Will work on holes that a plug won't? If not, will it work with in conjunction to a plug?
    Locally, there was a pothole that was stranding people by taking out both tires on the side. If damage worse than 'typical' is more common were you drive, shouldn't you be carrying two spares, just in case?
    This all about risk assessment and comfort. In the 30 or so years of personal memory, I have been involved in a half dozen or so flats that have been, or could have been, fixed by a plug kit. One required a side patch. One was that large bolt, which may or may not have fixed with a plug, a professional plug did fix it. And back when I was around 10, we had a tire blow out.
    Tire durability has improved with time. All new cars have TPMS to alert the driver to slow leaks, and the damage can be addressed before they lead to a blow out. Then there is cell coverage where I drive. So I wouldn't be concerned if the new car I want doesn't have a spare. Other peoples' experiences and local conditions can change that assessment and comfort.
  5. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    I've had two occasions in my younger life to use a spare, a bent rim and the other was just plain doing stupid stuff. I've had fast leaks that leave your tire flat in hours. I love those because everyone stops by your desk to tell you. At this point in my life I've learned to avoid the big ones and you can't do what they did on the Duke's oh hazard.
    You can't always safely use a car jack depending on shoulder conditions and traffic. If you plan on doing so carry some wood to stabilize the jack and chock the wheels.
  6. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Just got home with my brand new 2016 Two Eco. It has a spare and jack but no repair kit.
  7. bisco
    52,912
    congrats! all the best.(y)
    so, the thread, 'visual tables of gen 4 package combinations' shows that the two eco has no spare tyre. i think someone needs to pm tony p schaefer.
    #27 bisco, Jan 27, 2016
  8. frodoz737
    4,812
    2,563
    33
    Strange, Gulf States shows no spare on the 2016 2 ECO.
  9. energyandair
    905
    339
    Victoria BC Canada
    Does it have 3 door Smartkey and no rear wiper?
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    #30 Sergiospl, Jan 27, 2016
  11. priusgto
    194
    231
    Northern Arizona
    Has the rear wiper but not the 3 door SK. Odd because the brochure says Eco has the 3 door SK but no rear wiper.
  12. frodoz737
    4,812
    2,563
    33
    Sounds like you need to go back to your Dealership. Wiper and spare is not an ECO.
  13. priusgto
    194
    231
    Northern Arizona
    Test drove it in all modes, Eco, Power, Normal and EV. (y)
    Here's a pic of the window sticker and the rear window wiper. Maybe we got a special one. :D
    #33 priusgto, Jan 27, 2016
  14. Mendel Leisk
    42,381
    @priusgto
    Is there a badge on the back saying "Eco"?
  15. priusgto
    194
    231
    Northern Arizona
    Quite possibly not Eco. I emailed for a quote on a Two and when we were test driving it, the salesman was showing me the modes. Maybe the Eco is a charge to add the 3 door SK, the wheel covers and to remove the spare and the wiper. They all have Eco mode if this is the case.
    Mendel Leisk and Sergiospl like this.
  16. Sergiospl
    3,938
    1,351
    28
  17. priusgto
    194
    231
    Northern Arizona
    Nope, no badge
  18. bisco
    52,912
    must be euro.
  19. goldfinger
    535
    403
    Buffalo
    Hey you got a good car, they're all eco.
  20. vince22
    vince22 Active Member
    205
    249
    califorinia
    I hope you didn't got charge for Eco model. Eco badge with no rear wiper. Prius Eco.jpg
