Poll: What 240v Receptacle Do You Have ?
Discussion in 'Prime Plug-in Charging' started by Rob43, May 14, 2019.
  1. 10-30R
    1 vote(s)
    4.5%
  2. 10-50R
    2 vote(s)
    9.1%
  3. 14-30R
    2 vote(s)
    9.1%
  4. 14-50R
    8 vote(s)
    36.4%
  5. 6-20R
    3 vote(s)
    13.6%
  6. Other
    6 vote(s)
    27.3%
  1. Elektroingenieur
    2,515
    3,288
    Three Touring
    “Nonlocking” was part of a change in the 2014 edition of the National Electrical Code, for which the Report on Comments (PDF) gives the submitter’s explanation on page 70–312: “Locking type receptacles should not be used as they can increase the risk of damage to the receptacle and premise wiring, possibly exposing live parts, if the vehicle were to move while still connected.” Consider that a charging cable could be disconnected electrically, defeating the interlock, but still be connected mechanically or entangled with the vehicle.
    jb in NE likes this.
  2. NR427
    NR427 Member
    142
    100
    Utah
    Locking outlets aren't allowed but hard wiring is fine?(n)
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Hard wiring what to what?
    52,889
    hardwiring the box to the wall wiring, no plug.
  5. bisco
    52,889
    thanks. it is funny, you can't move the car when plugged in.:rolleyes:
  6. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Before your "Edit" I seem to remember reading that you wanted a longer charge time for either nights or weekends when you knew you weren't pressed for time. Since there's a lot of empty space on your nicely made panel & you have that 120 / 20amp outlet installed, you might consider hard mounting your Toyota OE EVSE or a nice used EVSE from Ebay so that you can slow charge at ~5 1/2 hours or longer when you deem necessary.
    Rob43
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Yes. You can hardwire the JuiceBox to the wall. This is one of the options offered by JuiceBox at purchase.
  8. bisco
    52,889
    but what if you drive off with the evse plugged into the car?
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't think you can. The car won't let you drive it when plugged into the wall. And even if you could, you would rip out the plug at the car before you tear the JuiceBox off the wall.
  10. bisco
    52,889
    see post #21 :rolleyes:
  11. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    The SAE's J1772 standard will not let you do that. Whether charging or not, the vehicle recognizes that it is attached to an EVSE and will not allow its drive-train to energize.
    source: http://ecee.colorado.edu/~ecen5017/lectures/CU/L40_slides.pdf
    Raytheeagle likes this.
  12. DavidA
    2,349
    1,825
    Chicago western burbs
    I can't think of what I might have mentioned that would indicate I actually wanted to increase the time of charging. I've plugged into a 120v 15A circuit while on vacation with the car, and at 8A (in the car) it took forever. It was the only option we had at the time, and it worked. At home, I absolutely don't want the thing plugged in overnight as it is parked outside and a few feet from the street. Don't want anyone getting funny ideas. Too many strange things happen in the neighborhood already at night. A 2 hr. charge is what I had in mind when I ordered the EVSE, and it has worked out beautifully.
    The 120v 20A can also serve for the corded power blower, circular saw, and possibly the Toyota-supplied charger cord if need be if the bigger EVSE craps out. When running the power out underneath the porch, it was a cheap option to add.
  13. DavidA
    2,349
    1,825
  14. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    ^ I must have read your post before you edited, incorrectly...
    EDIT: I thought I had read your statement from this thread, it came from the Tesla thread.
    Rob43
    #34 Rob43, May 20, 2019
  15. bisco
    52,889
  16. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    I have those outlets all over my house and garage some even are grounded.
    Besides the 12 amp 220vac limitation they seem to work fine, I am told they are notoriously fragile and short but I’m guessing as long as I don’t plug/unplug a lot and keep an eye on them there shouldn’t be any magic smoke
  17. bisco
    52,889
    we had those when we moved in here, house built in the 50's.
    but with metal boxes and ground wire, it was a pretty easy swap out
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This is why circuits are protected with breakers or fuses. If the receptacles work, I'd keep using them. If they eventually break, then replace them.
  19. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I am very surprised about the first 12 votes, I would've guessed that the 10-30R "Dryer Plug" would have the most votes.
    Rob43
  20. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I just use 120V. My cousin has a Leaf, and she just plugs in 120V over night. No real reason for hyper fast charging, but the panel in my garage is right where I’d put a 240V charger if we ever buy one, and I’d just hardwire it to some Romex inside a junction box. Easier, cheaper, and cleaner-looking than using a plug.
