Poor audio quality, 2018 Prius Three
Discussion in 'Gen 4 Prius Audio and Electronics' started by Phil Barry, May 17, 2018.
  1. Phil Barry
    Phil Barry Junior Member
    Chicago area
    2018 Prius
    Music, especially orchestral music, sounds electronic through the FM radio of my Three. I listen to WFMT, which I believe has a clean signal. In general, the sound I get from the sound system is much more electronic than I got from my previous car, a 2008 Elantra with the base sound system. What's the usual evaluation of the Prius sound system?
    Does mine have a problem, or is it just not very good?
    Thanks.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you fiddled with the sound settings (bass/treble/fade/balance) to see if it will improve?
    How does it go with a quality CD, or an MP3 on a USB stick
    52,862
    not very good. time to read up on better systems, there may be a progression of speakers, amp, h/u, not necessarily in that order.
  4. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    On my past Prius and now on my ‘17 Prime I have likes the stereo best when I adjust the Automatic sound levelizer (ASL) all the way to high. It provides a much richer sound no matter where I have the base and treble etc set. It is a speed sensitive adjustment I believe. Otherwise the stereo is kind of flat and lacking depth.
  5. Drhyed
    Drhyed Junior Member
    2018 Prius
    Thanks for the tip, just yesterday I was thinking mine sounded flat just as you mentioned. Im also having an issue that music sounds alright (I listen to EDM and 80's 90's 00's and todays Top 40 so its a mix lol) and also some sports radio and when radio talkers have heated discussions there voices will make it seem like the bass is to high or is overwhelming the speaker but I dont have the issue with music at all... very frustrating
  6. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    I made this adjustment and it does seem to improve the sound (or maybe just louder?). Thanks for the tip!
    Most if not all radio stations (Public Radio mostly excluded) use heavy compression and EQ the bass on the mics, Makes for a more manly sounding man.
    KilgoreTrout likes this.
  7. atterbury90
    atterbury90 Junior Member
    53
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    NPR could use some more manly sounding men for sure. I find the speakers and sound system in my 2017/2 to be tinny and just figured it was an area to cut cost to meet a price point. No feel of power to the system. I would like to upgrade the system if it is practical.
