Poor fuel economy
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jerry Liebler, Jan 7, 2017.
  1. bisco
    52,858
    should have known, when you said ev miles were fine. how odd to have a dirty maf at 33k. goes along with the brakes i guess.
  2. Mendel Leisk
    42,351
    Makes me wonder if I should do that: MAF cleaning. And not so good if it can go south like that, and not show a code or anything.
  3. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    As I said early in this thread, the air filter was extremely dirty, solid black with some form of soot, like it had spent it's life following a smoky diesel. It appears that Toyota uses MAF data to set most of the engine operating conditions, things like valve timing (effective compression ratio), spark advance, even EGR and of course fuel injection flow rate. However the fuel flow is "trimmed" to the desired ratio by looking at the exaust through the wideband oxygen sensor, AKA fuel air ratio sensor. Spark timing is, no doubt also modified by the knock sensor and EGR may well be "trimmed" to keep the knock sensor quiet. This all means that an honest MAF is vital for efficiency. An operating but dishonest MAF (dirty) probably doesn't increase exaust emissions and is not all that easy to diagnose with on-board sensors so no codes. Interestingly I now know that the "volumetric efficiency" readout from Torque did clearly show that there was a problem.
  4. Mendel Leisk
    42,351
    My brain is full, but it sounds like you're on top of it. (y)
    #44 Mendel Leisk, Feb 13, 2017
    Raytheeagle likes this.
  5. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    I do believe the problem has been solved! I just filled up, the first time after cleaning the MAF, It took 8.5 gallons to go 461 HV miles and went 91 EV miles on 19kw. So HV miles were at 54.24MPG, EV miles @ 161.4MPGE with 16.5% EV & 83.5% HV. So using my scoring method the weighted average is 116% of the EPA benchmark, certainly not my best tank but about in the middle of results I recorded on the spread sheet for the 2012
  6. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Good news .... and very interesting.
    Thanks for sharing
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Looks pretty good. Glad you got it sorted.
  8. Mendel Leisk
    42,351
    Yeah, that's excellent. Our more-or-less lifetime mpg is 49 mpg (US). Our BEST tanks are 54 mpg, a rarity.
    To convert liter/100 km to mpg (US), or vice versa: divide 235.2 by either value to convert, ie: 235.2/4.9=49
