Poor Man's ScanGauge Device
Discussion in 'Gen 3 Prius Fuel Economy' started by MarcusRepublic, Oct 18, 2012.
  1. MarcusRepublic
    MarcusRepublic Junior Member
    I wanted to share with everyone on the forum about how I track instant MPG readings while I drive without using a ScanGauge device in my 2012 Prius. I use the MPG readout on my odometer for Trip B. Each time, I enter my car, before I place my foot on the brakes to start the car, I tap the power button twice. This will turn on my electronics. I then reset my data from Trip B on my odometer. After that, I turn on my car and begin driving. As I drive it will tell me the instant MPG I am getting. I have adapted my driving around this to see when I drive my Prius most effectively and when I suffer in MPG loss during my normal route I take to work and school. However, this technique does not give me engine temperature or RPM readouts like the ScanGauge. If you are having trouble getting high MPGs, then this might work for you like it works for me. I am averaging 75+ MPG since doing this on my normal 10 mile commute. The highest I've gotten was 90.6 MPG!
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    You know there is an instant MPG slider indicator to the right of the speed right? And when you power off, you get a trip summary with the trip's MPG.
  3. MarcusRepublic
    Yep! I use that instant MPG slider indicator as well to figure what my average is at each second. I want to know how much MPGs I'm doing as I'm driving rather than finding out at the end when I turn off my car.
    52,612
    are you sure the trip meter is 'instant'?
  5. User37
    User37 Can spell PRIUS
    83
    Italy
    I thought the trip meter value is averaged over the last 20 kms (or so)
  6. bisco
    52,612
    well, if you reset it, it starts over and gives a pretty immediate reading. but i don't think it's instantaneous like a scan gauge.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  8. bisco
    52,612
    that link made me realize the op said instant mpg, but he's getting average mpg on the trip screen. same with the obd, but scan gauge gives instant current mpg.
  9. markabele
    5,084
    1,782
    Nebraska
    Got an Android phone? If so then check out Torque.
    WE0H likes this.
