Poor MPG, dealer said to change bearing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Korozive, Dec 18, 2011.
  1. Korozive
    Korozive Junior Member
    Montreal
    Thanks for all your advice, I really appreciate.
    I will probably change the battery before christmas just to be sure. Doesn't look difficult and/or long.
    With the aux. battery unplugged, will I have any problem after beside setting the clock ? Will I have a check engine , radio password to enter or alarm going like vw ?
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    yeah that's battery.
    Unlikely, but it might if battery shorts out completely. And it is cold enough it would be hard to overheat inverter.
  3. Kushuk
    Kushuk Junior Member
    Virginia
    FWIW: at 143k miles, after changing both rear wheel bearings with NSK KH30040 from rockauto (verified authenticity with WBA application), I'm seeing noticeably improved fuel economy, around 3 mpg +/- (with the second half of the same tank of gas as before), which is good because the loss was unaccounted for over the past few months. I changed them after a 16-hour driving day that resulted in the new sound of a small airplane/motorcycle/helicopter behind me. Cost was under $300, including the pair of bolts/washers/nuts I used to pull the bearings (btw, I had to double up the washers).
