POOR MPG IN THE RAIN
Discussion in 'Prius c Fuel Economy' started by KMAN4190, Jan 15, 2013.
  1. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    5-10% of 70 mpg: 3.5-7 mpg less. so if I get 70mpg when it's dry, 63-66.5 when it's wet.
    ztanos likes this.
  2. mahout
    mahout Active Member
    655
    116
    NC
    We have noticed in the past when drivers show up wanting us to fix poor mpg's that they were runing on cheap or worn tires that slipped a great deal; in rain the slipping isn't noticeable. The cure was a new of better set of tire(s) especially when one side is more worn than the other. Also you might check tire pressures about 35 psig, not much higher or lower. Just out of curiosity what are your tires? And might the diffrence between dry and wet driving you brake a lot more in the wet?
    cheers.
