Pop Quiz -- Horrible MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Bill Merchant, Mar 13, 2006.
  1. ckbarnard
    ckbarnard New Member
    56
    Bakersfield, CA
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I can't imagine why simply crawling down a long hill would return
    that sort of mileage. The heater shouldn't demand *that* much
    fuel-burn at 34 degF, unless you were trying to keep the cabin at
    like 80 degrees. Heck, once the cabin's warmed up a bit I generally
    turn the climate system OFF, and a little bit of heat leaks out
    the vents anyways which keeps things quite comfy. On a stretch
    like that I'd probably do several bars of 99.9mpg, popping to
    neutral on a regular basis [such as when stopped or just slowly
    drifting downward] and only let the engine run when I actually
    had some room and a need for acceleration.
    I regard this as fairly anomalous; the car should do better than
    that even without my particular OCD piloting style, and now I'm
    wondering what your corner parameter was that caused it.
    _H*
  3. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Sounds plausible to me if he was going under 10 mph generally, with lots of stops and starts, and not warm enough for any electric mode.
    I've gotton that low in traffic jams in summer on flat roads, where I needed the AC on.
  4. cmwade77
    cmwade77 New Member
    116
    Ok, care to tell us why the poor milleage?
  5. tomdeimos
    995
    Lexington, MA
    Anytime you run the AC you burn gas. If you are sitting still and not moving it counts as 0 mpg, and doesn't really matter what kind of car it is.
    When I had the bad mpg I moved about 1 mile per hour, in a big traffic jam. It was hot so I used AC and burned lots of gas.
  6. cmwade77
    cmwade77 New Member
    116
    Sorry, I meant the original poster, we've all been taking our guesses, I would like to find out which, if any are right.
  7. benighted
    benighted New Member
    530
    Westport, WA
    The answer was in post #35
  8. hobbit
    4,089
    469
    Bahstahn
    Yeah, but you likely don't run the AC when it's 34F outside...
    _H*
  9. cmwade77
    cmwade77 New Member
    116
    Thank you, somehow I missed it.
  10. benighted
    530
    Westport, WA
    Then how do you keep the windows from fogging up?
