Popping / cracking noise when raising or lowering the driver side window
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by morglum, Aug 6, 2016.
  1. morglum
    morglum Junior Member
    45
    gatineau,qc
    Hi everyone,
    I rented my car for a few days on Turo and it returned with this problem. The renter says nothing happened, who knows.
    When I raise or lower the window, there is a loud pop/crack that happens. It always happens at the same height. I can raise and lower the window for a couple inch around that point and reproduce that sound everythime.
    Note: I once backed into a column win an underground parking with my door open (dont ask) and it bent the frame around the window a bit forward. I "pulled" it back using my hands then, but I probably don't have exactly the same shape. That being said, that was a year ago and the noise only appeared now.
    BMW forums seem to suggest this is a window regulator problem. I havent seen anything here.
    Is there a quick, cheap fix? Can I just ignore it and keep using the window?
    Also, could there be any foul play by my renter? I dont see any bumps or scratches on the door.
    best
    49,725
    hard to say without seeing.hearing it. have you pulled the interior panel off?
  3. morglum
    45
    gatineau,qc
    guess I'll have to!
  4. morglum
    45
    gatineau,qc
    Hi all,
    Here is something new: I noticed that the pop/crack only happens when the door is fully closed or almost closed. If the door is more than, say, 1/4 open then the noise goes away.
    What changes in the door when it goes from fully open to almost closed?
    All I can think off is that metal "bar" that slides into the door and prevents the door from opening too much.
    I have pulled the panel off. But I dont think I can see where that metal "bar" goes even with the panel off. I checked the bolt holding the glass to the regulator - it was tight enough.
    any ideas?
  5. bisco
    49,725
    did you try putting it up and down with the panel off?
  6. bisco
    49,725
    good call on the door check, maybe try removing it? the only other thing i can think of is the light switch. unless the door is warping as it closes because of the accident.
  7. morglum
    45
    gatineau,qc
    H iBisco,
    I tried raising and loweing the window with the panel off, but there is not much to see as most of the interior is metal.
    Also, I need to leave the panel connected to the door by a bundle of electric cable to allow the power window buttons to work. Guess I could remove the power window button from the panel to allow me to completely remove the panel.
    I didnt know I could remove the "door check". I'll see what I can do.
    thanks
  8. morglum
    45
    gatineau,qc
    update: it was the door check.
    valde3 likes this.
