Popping or clicking sound
Discussion in 'Gen 2 Prius Main Forum' started by Bingshounds, Sep 23, 2021.
  1. Bingshounds
    Bingshounds New Member
    Iowa
    2007 Prius 140,000 miles makes a popping or clicking sound when go from stop and hit gas to accelerate and it’s only a single pop i have checked all cv axles and everything I can think of to check can something in the cvt make that noise it’s almost like there’s 2 pieces that come together that have a little play in them and when you go forward it pops with the little play in it only thing I can think of at this point is it’s in the cvt any help appreciated I can take a video if it would help diagnose the problem thanks in advance
    49,542
    i agree, could be a worn joint. can someone hear it next to the car when you hit the gas?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,487
    1,588
    NJ-USA
    With the car in park (and parking brake not applied) try rocking the car forward and backward to see if you can recreate the noise. Might be a bad cv joint, maybe some looseness between the outer cv joint splines and the hub (usually if the axle nut is not fully torqued), or something else.
